2 members (DaveK, M3WMW),
277
Topics49,911
Posts838,148
Posts: 28,912 Likes: 354
Posts: 28,912 Likes: 354 |
Do you have alloy or wire wheels? If wires there is also the possibility of wear in the centrelock splines.
Posts: 59 Likes: 1
Posts: 59 Likes: 1 |
Hi Graham, I have wires , took them off today to clean them well it is Father’s Day and spending a few hours cleaning wheels is a dad thing . Checked them and all seems fine though Goliath’s big brother must have put them back on after it’s service took some getting off
Posts: 2,095 Likes: 75
Posts: 2,095 Likes: 75 |
Hi Graham, I have wires , took them off today to clean them well it is Father’s Day and spending a few hours cleaning wheels is a dad thing . Checked them and all seems fine though Goliath’s big brother must have put them back on after it’s service took some getting off Does this mean that the clunking has now gone? Whenever I have had a clunking sound ( or perhaps more a of a “dunk” sound) from the back, especially when reversing direction, I have simply removed the wheels, cleaned and regreased the splines and mating surfaces and it has cleared the problem.
Posts: 381 |
Check the fixation of the rear exhaust item.
Regards 2005 PLUS 4
Posts: 59 Likes: 1
Deejay . No it made no difference , I need to find out what oil was put in the rear axle at service and go from there
Posts: 59 Likes: 1
Spoke to the guys at oakmere re the oil and that wasn’t changed so the leak isn’t down to them so sorry lads crossed wires there , so may change the axle oil and see if that sorts the clunking if not I’ll let them have a look . I’ll let you know how it goes
Posts: 59 Likes: 1
Further to the clunking issue I changed the oil in the axle to the recommended for a BTR axle as I have no idea what was in there or how long though it only has 40k on the clock .the amount I took out was 1.25 litres so down quite a bit then put 1.7 litres and no clunking ! I also checked the old oil to see if there was any debris in and not a bit so hopefully no damage done
Posts: 8,703 Likes: 501
Posts: 8,703 Likes: 501 |
Good result  If it's been in 40k miles that oil's nackered
Posts: 27,846 Likes: 765
Posts: 27,846 Likes: 765 |
Bit of a conflict on oil advice in this posting. The handbook for my 2011 +4 BTR axle) states 1.7 litres of 80w140 semi synthetic for the rear axle. When I changed mine 4 years ago, the nearest I could get was Castrol 75W140 Syntrax.
So wondering where the specification of a 75w90 came from? Incidentally, the handbook states the same oil for the whole range of models, so don’t think it’s a typo.
