0 members (), 309 guests, and 37 robots.
Topics49,860
Posts837,486
Jonny72
Michael, that's exactly right. I had fuel line leaks a couple of weeks ago because the original 2012 rubber degraded. I swapped both lines as well as the "shared line" between the towers, with 5/8 inch fuel injector quality hoses (thicker and made for higher pressure). I also just the other day swapped out the worm clamps with fuel injector clamps made for the job (this was Ian's suggestion). Wasn't hard to do. Haven't taken it for a long ride to "stress test" it yet, but it looks like we're all good after driving it around the neighborhood.
end user
O
O
Unfortunately my bevel box has got noisier over time so have been trying a few oils.
Out of these the Millers and Amsoil were very similar and although I had high hopes for the Redline it was noisier.
None of them are a miracle cure though but will try Millers EP140 next.
How much oil were you putting into the BB?
O
O
350ml is all it takes and that's with the rear a bit higher than level. Do you suggest over filling?
No.
O
O
I have been using Millers EP140 from day one with good results.
