6 members (bmgermany, Ian Wegg, John Winn, DCH, RichardV6, Graham, G4FUJ),
321
88
Topics49,847
Posts837,389
Posts: 212 |
Michael, that's exactly right. I had fuel line leaks a couple of weeks ago because the original 2012 rubber degraded. I swapped both lines as well as the "shared line" between the towers, with 5/8 inch fuel injector quality hoses (thicker and made for higher pressure). I also just the other day swapped out the worm clamps with fuel injector clamps made for the job (this was Ian's suggestion). Wasn't hard to do. Haven't taken it for a long ride to "stress test" it yet, but it looks like we're all good after driving it around the neighborhood.
end user
Posts: 488 |
![[Linked Image]](https://www.tm-img.com/images/2021/07/18/63522EB4-283B-434D-A833-DA52552DF10C.jpg) Unfortunately my bevel box has got noisier over time so have been trying a few oils. Out of these the Millers and Amsoil were very similar and although I had high hopes for the Redline it was noisier. None of them are a miracle cure though but will try Millers EP140 next.
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
How much oil were you putting into the BB?
Posts: 488 |
350ml is all it takes and that's with the rear a bit higher than level. Do you suggest over filling?
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
350ml is all it takes and that's with the rear a bit higher than level. Do you suggest over filling? No.
Posts: 488 |
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
I have been using Millers EP140 from day one with good results.
