Topics49,849
Posts837,410
Posts: 1,544 Likes: 1
Posts: 1,544 Likes: 1 |
Hi guys anybody experienced clutch pedal getting full travel and clutch not working ,too pumps its back up but bite point different place. spoken to Clutch Specialist in Leeds he reconds morgan uses the wrong size slave cylinder (internal type) which causes problems!! any thoughts??
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
Had a clutch problem on a friend's Brooklands. It started off like yours but got progressively worse 'till it didn't operate at all. We bled the system & then changed the master cylinder, neither of which cured it. In the end, we took it to Phil Bleazey where we fitted a replacement (Volvo) slave cylinder while having the Centa upgrade done. Check out this THREAD for more detailed clutch information. I have a spare master cylinder if you want to try it? Might just be your problem and it's certainly easier to replace than the slave cylinder.
Andy
cheers Andy but talking to several mechanics it sounds odds on slave so engine coming out , the guys in Leeds said send all clutch parts to them they test it alll out and may be able to replace any parts with something much better! the game commences
Unfortunately my money would be on the slave cylinder too. However, I would still try the master first, just in case. It's a hell of a lot less work...
Also, have a word with Phil Bleazey - he has seen more M3W clutches than anyone else and has sourced some replacement components.
Andy
 Expect a call tomorrow Phil
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
Hi guys anybody experienced clutch pedal getting full travel and clutch not working ,too pumps its back up but bite point different place. spoken to Clutch Specialist in Leeds he reconds morgan uses the wrong size slave cylinder (internal type) which causes problems!! any thoughts?? Similar symptoms to master cyl on its way out on the later classic 4W Mogs (same cyl) If you start the engine, keep the clutch pedal depressed in gear, if eventually the car (trike) starts to creep then it's the master cyl fluid leaking past the internal piston seal under pressure, no external leak shows as it just bleeds back & fills the reservoir
Posts: 399 Likes: 15
Posts: 399 Likes: 15 |
We had master cylinder fail with symptom that with foot down the clutch would slowly engage. Slave failure is usually accompanied by fluid loss - we saw no fluid loss and replacing the master fixed it - the rubber washer/seal had started to split. Changing this is a bit of a struggle given access but less momentous than getting to the slave cylinder...Good Luck!
Slave failure is usually accompanied by fluid loss Normally this is the case, but often when the M3W (Volvo) slave fails there is no fluid loss.
Andy
engine coming out and being Bleazed  and new slave fitted  its only time and money
Posts: 38 |
its only time and money  We should all have this tattooed on our backsides...
