0 members (), 297 guests, and 100 robots.
+8Rich 78
Topics49,872
Posts837,704
Rudolf
asmair Offline OP
Thanks for the advice. I think I have worked out what the purpose is of the thin wire from the from the hot side of the battery isolator switch. This must be the power feed for the immobiliser, am I correct?
Yes and the clock if fitted
asmair Offline OP
Alas, no clock, but I do have a 7 day clockwork aircraft clock that I was thinking of fitting.
Blooming heck, I've had mine since 2015 and have never had an immobilizer fob, like you I use the isolator key all the time. Has anyone had intermittent problems related to the immobiliser module at all, I am chasing an intermittent fault and could do with eliminating this unit.
