4 members (gomog, Vansrv6, TBM, Alistair), 300 guests, and 37 robots.
+8Rich 92
Topics49,839
Posts837,302
Page 1 of 5 1 2 3 4 5
#710349 18/07/21 10:14 AM
Hello Guyes,
here is my last invention, the new Morgan filter cover.
Made from aluminium, polished, same material as engine.
Much less vibrations in relation to original cover.
https://drive.google.com/file/d/1ZAxJIyUPv3pWdIpEFwfGjd_NLWGsOOUM/view?usp=sharing
https://drive.google.com/file/d/1ZBivW-HkN-9igWeClJvT3I6eKjRui3_V/view?usp=sharing
https://drive.google.com/file/d/1Z41CbjD2AYsXdOShAPsfqzAtVBL1K3cp/view?usp=sharing
Your opinion?
Andrej smile
Love this! Does it fit the standard filter or the S&S upgrade?
Hi Lindo,
that is fit instaed original filter cover.
Only the four mounting posts are shortened cca 4mm, so the filter is fixed...
Now that looks nice👍 Add a metal stinger in it and it would have more air flow than the S&S Stealth and work as well or better.
Nice Job
how was the logo engraved ? 🧐
Lille - France
Plus Four 2024
Looks great!
Scott
2018 M3W
1995 Porsche 993
This is CNC cutter work.
Lot of people is asking what is it, Morgan is not written on the car...thats why Morgan... :-)
I like it ... good job!
Why did you change the rectivier to the HD version? Did you have problems with the orginal one?
How did you mount it on the frame in that position ... could you post some photos?
Is this an oil cooler on the left side? Can you explain a little bit more about this detail?
You have only one turning light on the back side of the car (not the double unit as orginal)... is this still the original one (reworked) or do you use "all in one" turning lights from aftermarket?
Are you happy with the Michelin Commander tyres?
Eddy
built not bought - hustled not handed - earned not given - rare not average
Lot of questions :-)
Rectifier is new after failure, it is mounted together with new oil cooler on new holder. Oil coller is passiv on oil output to system tank.
https://drive.google.com/file/d/1PjYXZVKKiIdvWyVxEQ08SECPfxiJ4srS/view?usp=sharing
https://drive.google.com/file/d/1K6ozgiEYfN-ZCr5DDv-VoQUroFHbyLyp/view?usp=sharing
Yes I have only one turning light, seems much better, front headlights are lower and wider and turn lights are on the side of them.
To reworke from two lights to one is easy.
Michelin is top, specially on wet road, the original tire is a horror :-)
Mudguards are smaller, open and cca 50% lighter
Best regards
Andrej
