7 members (Image, JohnHarris, Mats, Montegue, stumog, Gordon D, John V6),
413
85
Topics49,848
Posts837,408
Posts: 592 |
The spacers were originally fitted to mine with the original bolts, I had to get longer bolts and also tap the holes deeper as one of the threads was stripping.
M3W Brooklands (2015) Moody 41 (2013)
Posts: 77 Likes: 3
Posts: 77 Likes: 3 |
I dont like the spacers in between the motor housing and the cam cover because of air and rain water.
Unfortunately I dont really see and understand the venting solution on the photos above…did S&S cut some slots into the cam cover…could somebody post detailed photos how the final or actual solution of the vented cam cover is made?
Icould do the job on a milling machine by myself…but I would like to do no mistakes.
Eddy
built not bought - hustled not handed - earned not given - rare not average
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Icould do the job on a milling machine by myself…but I would like to do no mistakes. Look on the X-Wedge Parts Book for a view of it. It should be there. I stand corrected, the photo of it is of the original and not the one that has machined slots. Send me a PM with your email address and I will send you a photo of the cover.
Posts: 77 Likes: 3
@ LightSpeed - good idea... I just looked for images on google and found this intersting way of venting inside the transparent cover: https://www.given.it/en/prodotto/carter-distribuzione-x-wedge-ss-e-crs-duu/I will check if I can do it in a mostlikely similar way!
Eddy
Someone sure spent a lot of time with a cnc machine to make that!!
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
Lot of time with the software to control the CNC perhaps? ![[Linked Image]](https://www.given.it/wp-content/uploads/SS-Cam-Cover-3-1.jpg)
My point exactly, since the machine would not operate without it.
Posts: 77 Likes: 3
I found now some photos here… http://www.talkmorgan.com/ubbthreads.php/topics/710089/one-of-the-last#Post710089You can See 2 small slots at the cam cover… is there a third one on top in Order to create an air flow inside this area?
Eddy
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
As well as the two slots on the underside of the raised bars on the front of the cover there is a slot cut in the base of the cover, again out of normal sight. The cars that have the slots in the cover from manufacture still have the spacer washers fitted.
