Topics49,877
Posts837,733
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
I think that the immobiliser ring is the most likely, even though you had it replaced 2 years ago. Some have had this problem repeatedly and others not at all. So, it seem to be an unreliable component. I believe Dave W has given advice in the past about first holding the key against the ring for a few seconds and then starting within 30 seconds. I thought the immobiliser ring problem happened to certain Plus 4’s only. GDI’s.?
Craig Jezz
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
I think that the immobiliser ring is the most likely, even though you had it replaced 2 years ago. Some have had this problem repeatedly and others not at all. So, it seem to be an unreliable component. I believe Dave W has given advice in the past about first holding the key against the ring for a few seconds and then starting within 30 seconds. I thought the immobiliser ring problem happened to certain Plus 4’s only. GDI’s.? So far, nobody on TM with a 4/4 has recorded trouble with the ring, but only the dealers will know for sure.
Posts: 2,093 Likes: 75
Posts: 2,093 Likes: 75 |
I think that the immobiliser ring is the most likely, even though you had it replaced 2 years ago. Some have had this problem repeatedly and others not at all. So, it seem to be an unreliable component. I believe Dave W has given advice in the past about first holding the key against the ring for a few seconds and then starting within 30 seconds. I thought the immobiliser ring problem happened to certain Plus 4’s only. GDI’s.? Sorry, I never checked that out....mea culpa!
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
Only asking....
Why would the immobiliser ring be different between the Plus 4 and the 4/4 of the same manufacturing years.
I can guess that the ECU might be different but I would have thought the steering column electrics and instrument electronics would probably be the same.
I'm asking so the immobiliser ring does not get ruled out of this diagnosis IF indeed it could happen.
Is it DEFINITE that the problem only occurs on the Plus 4 ??
Bob
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
Thank you all for your proposals! We found the problem, everything works well now  The starter relay had a bad connection to the socketI had checked all the fuses for poor contact before, but not the relays.
