2 members (CooperMan, JoeSpeetjens), 327 guests, and 87 robots.
+8Rich 66
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,878
Posts837,745
Originally Posted by Deejay
I think that the immobiliser ring is the most likely, even though you had it replaced 2 years ago. Some have had this problem repeatedly and others not at all. So, it seem to be an unreliable component. I believe Dave W has given advice in the past about first holding the key against the ring for a few seconds and then starting within 30 seconds.
I thought the immobiliser ring problem happened to certain Plus 4’s only. GDI’s.?
Craig Jezz
So far, nobody on TM with a 4/4 has recorded trouble with the ring, but only the dealers will know for sure.
Sorry, I never checked that out....mea culpa!
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Only asking....
Why would the immobiliser ring be different between the Plus 4 and the 4/4 of the same manufacturing years.
I can guess that the ECU might be different but I would have thought the steering column electrics and instrument electronics would probably be the same.
I'm asking so the immobiliser ring does not get ruled out of this diagnosis IF indeed it could happen.
Is it DEFINITE that the problem only occurs on the Plus 4 ??
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
Thank you all for your proposals!
We found the problem, everything works well now happy3
The starter relay had a bad connection to the socket
I had checked all the fuses for poor contact before, but not the relays.
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
