6 members (bmgermany, Alistair, teknome, Zach, Grumpy2, Montegue), 248 guests, and 82 robots.
Sagging Hood
Topics49,859
Posts837,481
Page 2 of 5 1 2 3 4 5
I
I
The spacers were originally fitted to mine with the original bolts, I had to get longer bolts and also tap the holes deeper as one of the threads was stripping.
M3W Brooklands (2015)
Moody 41 (2013)
I dont like the spacers in between the motor housing and the cam cover because of air and rain water.
Unfortunately I dont really see and understand the venting solution on the photos above…did S&S cut some slots into the cam cover…could somebody post detailed photos how the final or actual solution of the vented cam cover is made?
Icould do the job on a milling machine by myself…but I would like to do no mistakes.
Eddy
built not bought - hustled not handed - earned not given - rare not average
Look on the X-Wedge Parts Book for a view of it. It should be there. I stand corrected, the photo of it is of the original and not the one that has machined slots.
Send me a PM with your email address and I will send you a photo of the cover.
@ LightSpeed - good idea... I just looked for images on google and found this intersting way of venting inside the transparent cover:
https://www.given.it/en/prodotto/carter-distribuzione-x-wedge-ss-e-crs-duu/
I will check if I can do it in a mostlikely similar way!
Eddy
I will check if I can do it in a most likely similar way!
Someone sure spent a lot of time with a cnc machine to make that!!
Nice to see a Euro X-wedge accessory company - like their transparent air filter too!
https://www.given.it/en/prodotto/filtro-aria-per-motore-ss-x-wedge/
Lot of time with the software to control the CNC perhaps?
My point exactly, since the machine would not operate without it.
I found now some photos here… http://www.talkmorgan.com/ubbthreads.php/topics/710089/one-of-the-last#Post710089
You can See 2 small slots at the cam cover… is there a third one on top in Order to create an air flow inside this area?
Eddy
As well as the two slots on the underside of the raised bars on the front of the cover there is a slot cut in the base of the cover, again out of normal sight. The cars that have the slots in the cover from manufacture still have the spacer washers fitted.
