1 members (Plus Four Guy), 229 guests, and 28 robots.
+8Rich 101
John V6 63
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,214
MossyfromNZ
the crankshaft position sensor only deteriorates if the cable is fixed on the chassis instead of being fixed on the engine, I have never had a problem with mine with more than 100,000 km.
Thats a good point. The engine vibrates so much that the shaking would fatigue the cable.
Originally Posted by Black Adder
It might be worth trying the S&S 106-0744 Crank Position Sensor, not a cheap part but has been known to degrade and cause this type of inconsistent error.
It's definitely worth slipping it out and giving it a clean. It won't cost anything and just might make a difference?
Andy
It's definitely worth slipping it out and giving it a clean. It won't cost anything and just may make a difference?
I didnt know this was accessible without an engine out job - is there a write up on this somewhere ? Thanks
Just undo the hex head screw and slip it out.
Andy
Just put the new sensor directly to his connector And Check it
BearDee Offline OP
Many Thanks everyone, I will try reset ting the Map first as the problem only started after installing the new Walbro Fuel Pump. If that doesn't work then yes, I will try all of the above
Did you check the fuel pressure after fitting the new pump?
Or did you assume - as we all would - that new pump = correct pressure?
I ask as we have had a customer who fitted a new Walbro pump and then started having running issues - new pump was showing 68 PSI at test point.....
BearDee Offline OP
No
I didn't check.
I have no running issues at all, it's just the starting.
