9 members (sewin, flyfisher, Ricosan, jbk, Graham, G4FUJ, Clipper, John V6, Scrambledsignals, TBM),
305
49
Topics49,918
Posts838,246
Posts: 10 |
Hi All, I'm in the process of changing out my fuel pump on my 2020 M3W as a precautionary measure to a Walbro unit, can somebody tell me how to remove the pump hoses please ?, I've had a look at the TM how to guide but my hoses appear to be different to those shown. Regards Dave. ![[Linked Image]](https://www.tm-img.com/images/2021/07/27/IMG_2544.jpg) ![[Linked Image]](https://www.tm-img.com/images/2021/07/27/IMG_2543.jpg)
2020 Plus 4 Rhapsody Blue 2020 M3W Orange Shark
Posts: 488 |
You can see the little bit you need to push in with a screw driver in the bottom left picture, push in and pull fitting off, the top right fitting will need rotating to see bit you push in.
Posts: 10 |
There are two tabs one either side on each plug, unless there is a specific tool available it looks like i need three hands .
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
This picture is the other end on the filter but the same connector just use a small screwdriver to press the tab in and the connector will slide off. The lower one in your picture is on the side, the upper one is underneath. ![[Linked Image]](https://tm-img.com/images/2018/02/20/IMG_1844.jpg)
Posts: 1,562 |
You can buy a special tool to help do this : https://www.amazon.co.uk/Fuel-Feed-...&hvtargid=pla-762224342357&psc=1but equally can be done with a screwdriver to push the tab in , plus some dexterity twisting the pipe.
Posts: 9,554 Likes: 134
Posts: 9,554 Likes: 134 |
Carefully use a thin nose pliers to push in the locking tab and pull the fitting off the pump connection. LIGHT pressure with the pliers only. One hand on pliers and pull with the other. Put a cloth underneath to catch any fuel.
Posts: 2,243 Likes: 73
Posts: 2,243 Likes: 73 |
You have the standard hose end fittings Dave, you just need to push the tab correctly and wiggle the hose end. It will come off but they can be reluctant to move at times, there is no easy way.
If you want to replace the hoses and end fittings with some slightly easier quick release fittings look on eBay for "Bundy Type 7.89mm ID6" for the fittings and 7.3mm ID Ethanol proof fuel hose J30R9 73379 Type 3E, plus 11-13mm fuel hose clips.
