0 members (), 309 guests, and 37 robots.
Topics49,860
Posts837,486
Jonny72
CJB #712100 30/07/21 03:05 PM
Originally Posted by CJB
What year is the 35th. Anniversary Edition? Presumably a later version of my 3.9 V8. That's a hell of a difference in price for the pump!
That is the problem..also being asked of me in another thread.
This V8 has gone through many variations, some of the most painful close to its demise.
1. You have the V8s made up until 1976, which can be very well (aka better) supplied by the US Buick 215 market.
2. Then you have the mighty Sd1 era (1977-1990) but even this era has sub-divisions into different fuelling systems, carbs, flappers (Morgan uses a flapper model made for Morgan and TVR and Marcos...
3. Then you have the 3.9/4.2 era, fueled by Hotwire variations
4. Then you have (shiver) GEMS
And (what joy!) Morgan stopped following the Rover/LandRover changes time-wise many years ago. Additionally, overseas variants became very different from UK/Europe in comparable componentry year over year...sometimes the same but often different.
One of the big thingies changed was the front timing cover, which is FAR more than a front timing cover on this V8..holding the oil ant water pumps and distributor..until Morgan stopped in 1998 (for Overseas) and 2000 for everywhere else. The timing covers for GEMS quickly became unobtainable and hyper-expensive. Sadly, the oil pump wears like all versions do and since it is a part of the timing cover..one has a limited future. I have helped a number of owners switch back to a distributor so they can back on the road with an older timing cover.,http://www.mez.co.uk/tuningtheroverv8-pt6-new.html They are happier when they see the performance! But many countries won't allow such things I understand. By there are ways......
As you can see hints of, 1000s can be saved a year for repairs taking minutes..as long as you know which is the right part for YOUR +8. We go to dealers (who are all overworked now) because we lack knowledge in this maze, not because you are totally incapable. Frankly, looking around in the West today, if I had to do it over and retire early again, I would become a roadside mechanic today rather than a specialist lawyer.
l
CJB #712101 30/07/21 03:08 PM
2003/4. VERY different from your 3.9....reason for great happiness.
CJB #712104 30/07/21 03:26 PM
CJB Offline OP
My pump doesn't look like any of those unfortunately. Good idea on the bolts.
This looks like mine:
https://mogparts.net/product/water-pump-8-5-speed-to-1996
1990 +8 Connaught Green
1970 Lotus Elan S4 SE
1973 Lotus Europa TC/Special
CJB #712108 30/07/21 03:50 PM
looks like a serpentine pump to me?
06 Saab 93
gomog #712109 30/07/21 03:52 PM
CJB Offline OP
Mine is a 3.9 with Hotwire EFi. It actually has TVR written on the block in felt tip so obviously a Leyland delivery got diverted!
CJB #712110 30/07/21 03:53 PM
Get the engine number (on the block) and give RPI Engineering a call, they'll tell you exactly the Rover part number, rather than a dealer stock control number.
06 Saab 93
CJB #712112 30/07/21 03:55 PM
Remember it's a Rover V8, and there are far more RV8 enthusiasts out there than the number of plus 8s actually built!
06 Saab 93
CJB #712116 30/07/21 04:26 PM
How unusual! I had a 1990 as well. 1990 was a transition year. My R10326 was (originally) a sd1 3.5 Flapper. I had the impression you had a 3.9 You are disolaying a Flapper 3.5 pump. Take a look at this page. https://www.gomog.com/allmorgan/pumps.htm
Sd1 pumps are easier to find. At least they used to be.
https://www.ebay.co.uk/itm/143332386214?hash=item215f46a5a6:g:kbgAAOSwZn9fhaWd
https://www.ebay.co.uk/itm/292848609182?epid=14026728717&hash=item442f23279e:g:HSoAAOSwIw1cClcB
You might have to have the nose of the pump cut off. That did what Morgan did in most cases. Use your current pump as a template at a machine shop. That is what Melvyn likely did. Follow his lead..just don't pay his prices..5 times more than its worth! rofl
Remember, that the most important tool in any mechanics box is patience.
L.
P.S. Next time we will have you change your clutch slave AND make it so you rid yourself of the Maurice Owen clutch slave curse (1977-1993ish)
gomog #712189 31/07/21 08:53 AM
CJB Offline OP
Tell me about the clutch slave cylinder. I must be lucky, had the car from new with few problems. I once lost the clutch in Italy, topped up the fluid and it's been fine since!
CJB #712216 31/07/21 12:53 PM
Sure, CJB. But let's do so on a new thread with the appropriate title.
Lorne
