10 members (Willowgreen320, Hamwich, Alan Patterson, MATTMOG, sewin, RobS, Rog, High Hamster, stumog, Morganmike), 273 guests, and 42 robots.
+8Rich 91
Luddite 50
Posts837,969
#713312 08/08/21 04:20 PM
griffo Offline OP
I wonder if anyone can help with this issue. I have changed (with considerable difficulty) the handbrake cable after suffering from overheating rear brakes on my 2014 GDI Plus 4. Now, even though the handbrake cable is disconnected, I cannot get the shoes back on, even with lots of centering and fiddling. How can I release the self-adjuster on these later brakes to effectively reduce the diameter of the shoes? I do not want to remove the shoes completely unless I have to.
Many Thanks.
griffo #713313 08/08/21 04:22 PM
There is a hole with bung in it on the back plate to release them.
If you go to gomog the picture on there will make sense of it and provide location.
griffo #713323 08/08/21 05:02 PM
This may help. Shows the release of the adjuster.
griffo #713328 08/08/21 05:48 PM
griffo Offline OP
Many thanks. I'll give it a try. Of course in my first post I meant to say -- I cannot get the drums back on. Cheers.
griffo #713367 09/08/21 07:32 AM
Sounds to me more like sticking slave cylinders
Simon
2002 4/4
2021 Audi A1 sport
griffo #713429 09/08/21 05:50 PM
Griffo, you can just make out the little serrated pawl at about 10 o'clock if this helps, just lever it apart and it should spring in and allow the shoes to retract
griffo #713553 10/08/21 06:53 PM
They are notoriously awkward to reassemble - take care & you should be OK 👌
ArthurSBell
N44MOG Rolls Royce Green +4
M22ASB Grey Renault Megane Cabriolet
M10SAB White Fiat 500
The trick is to remember exactly which order you took them apart in I found and a couple of pictures helps before you start.
