8 members (Rudolf, Laurens, Clipper, Ian Wegg, Paulxj, +8Rich, Alan Patterson, DCH),
200
56
Posts837,942
Posts: 663 Likes: 14
Posts: 663 Likes: 14 |
I wonder if anyone can help with this issue. I have changed (with considerable difficulty) the handbrake cable after suffering from overheating rear brakes on my 2014 GDI Plus 4. Now, even though the handbrake cable is disconnected, I cannot get the shoes back on, even with lots of centering and fiddling. How can I release the self-adjuster on these later brakes to effectively reduce the diameter of the shoes? I do not want to remove the shoes completely unless I have to. Many Thanks.
Posts: 37,465 Likes: 988
Posts: 37,465 Likes: 988 |
There is a hole with bung in it on the back plate to release them. If you go to gomog the picture on there will make sense of it and provide location.
Posts: 1,246 Likes: 30
Posts: 1,246 Likes: 30 |
This may help. Shows the release of the adjuster.
Many thanks. I'll give it a try. Of course in my first post I meant to say -- I cannot get the drums back on. Cheers.
Posts: 521 Likes: 2
Posts: 521 Likes: 2 |
Sounds to me more like sticking slave cylinders
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
Posts: 8,692 Likes: 498
Posts: 8,692 Likes: 498 |
Griffo, you can just make out the little serrated pawl at about 10 o'clock if this helps, just lever it apart and it should spring in and allow the shoes to retract ![[Linked Image]](https://www.tm-img.com/images/2020/04/21/AP-brakes-3.jpg)
Posts: 86 |
They are notoriously awkward to reassemble - take care & you should be OK 👌
ArthurSBell N44MOG Rolls Royce Green +4 M22ASB Grey Renault Megane Cabriolet M10SAB White Fiat 500
The trick is to remember exactly which order you took them apart in I found and a couple of pictures helps before you start.
