9 members (Paul F, Graham, G4FUJ, SailingTom2, andymog1, BertR, Image, ChrisConvertible, BLUE+4, Rastus), 249 guests, and 25 robots.
+8Rich 99
John V6 57
Topics49,908
Posts838,121
Page 4 of 6 1 2 3 4 5 6
meabh #714607 18/08/21 06:24 AM
I guess the main disadvantage of fitting an isolator is that the ecu loses it’s memory each time? I recall some years ago when I disconnected my battery, on restarting, the engine sounded pretty rough for the first 10 seconds or so.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
meabh #714618 18/08/21 08:49 AM
My Plus 8 seems unchanged with the interruption of power to the ECU, I can kid myself that the start up tick over is marginally higher but it's only when the engine and ambient is cooler really.
Interesting to read of your findings though on a different and more modern engine.
+8Rich #714619 18/08/21 09:05 AM
Mine was quite rattly, as if the timing wasn’t right. Since then, I have always connected a spare battery in parallel before disconnecting the main one.
Doug
1958 Triton 650
Deejay #714621 18/08/21 09:22 AM
Interesting, a friend of mine was advised to do just the same when he changed his MINI one but was given no reason why. Your experience would have put me off too.
meabh #714623 18/08/21 09:36 AM
With my previous Morgan Roadsters, the battery switch was important because the battery was completely drained after 12 days. Unfortunately, I had to drive about 100 km before the engine felt lively and willing again.
The 4/4 also has a battery switch but it would not be so necessary and I hardly use it because the battery started even after months. Here the effect of learning after interrupted power in the ECU is also present but not as noticeable as in the Roadster.
meabh #714626 18/08/21 09:52 AM
My S1 Roadster experience is quite different. I don't use the conditioner continuously, just every few weeks. A battery change at 13 years didn't seem to affect performance at all, and it will hold charge, certainly in summer for at least 3 months.
Whereas my Plus 4 loses charge after a week or so, which means I use the conditioner more often.
My Golf which sits outside and may not run for 3 months in winter holds charge for months.
meabh #714629 18/08/21 09:57 AM
My S1 did not have a battery switch, but with S2 and S3 I noticed the difference after power interruption.
+8Rich #714638 18/08/21 10:19 AM
Possibly to not lose the radio code?
That makes sense Graham.
meabh #714700 18/08/21 06:39 PM
The 4/4 and +4 had isolation switches my Roadsters havent
