10 members (cerealsurfer, Graham, G4FUJ, andymog1, Paul F, SailingTom2, BertR, Image, ChrisConvertible, BLUE+4, Rastus), 223 guests, and 34 robots.
+8Rich 99
John V6 57
Topics49,908
Posts838,121
Page 3 of 6 1 2 3 4 5 6
meabh #714344 15/08/21 11:41 AM
meabh Offline OP
Hello all
I have just received this photo from my English friends who tells me that the rapid clicking is emanating from the silver piece, which at this distance I don't recognise but guess is attached to the starter motor. Any offers please/
meabh #714348 15/08/21 12:11 PM
Where do each of the pipes go? It looks like a solenoid valve...is it in the fuel line? They don't look like fuel pipes.
The flutter could still be caused by a relay. Have the relays been checked for clicking while this is going on?
SALMO #714354 15/08/21 12:55 PM
Originally Posted by SALMO
Hi meabh,
My car's a 4/4 2006 build but I'm sure the p4 relays are in a similar position as mine......
....behind the dash, high up, just left of the steering column when looking forward. Use a mirror to see them. Unless slim wristed and mobile detach the dash to change.
Hope this helps.
If he decides to look behind the dash for relays, an,d has no spare ones. available, suggest he checks by substitution...swap the extreme left hand (Start) relay with the extreme right hand one (high. speed fan) and see if it will start then.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
meabh #714371 15/08/21 02:47 PM
meabh Offline OP
Thanks Doug. I think that he has decided to take it to Tim Ayres(New Elms) nearby . It's frustrating not to be able to just go round and sort it.
Mr W, re: photo. it is all attached to the starter motor.
Time for tea and cake I think.
meabh #714446 16/08/21 11:00 AM
Tap the starter solenoid with a soft faced mallet, whilst someone turns the key ?
Worth a try if the car's been stood a long time / damp storage
meabh #714484 16/08/21 04:33 PM
meabh Offline OP
Tried that Jon but here is an update ( I guess all things are useful ) : New Ems now has it and report that the battery is not holding a charge. This is a new - days old - battery from Halfords and the second battery in two years. Does this suggest a battery drain? Remember that the car has been unused for nine weeks and even with a new battery would only start with jump leads. My friend also reports that on a very hot day last summer it stalled and would not restart until ten minutes had passed. I put that down to fuel starvation caused by the heat as I have experienced the same thing once. Anyway I will update this when Tim Ayres has had a thorough look at it because this might help someone else.
meabh #714487 16/08/21 05:02 PM
The clock if you have one is a drain as is the immobiliser. On the P4 you can use the isolator switch to turn everything else off but 9 weeks is a long time.
meabh #714592 17/08/21 06:36 PM
meabh Offline OP
Evening all,
This update is as follows: P4 now fitted with a Bosch battery and starts. As John said, nine weeks is a long time for a car to stand. I don't think it has a clock so if there is a batterty drain then the finger points towards the immobiliser. Fitting an isolator switch might be a good idea anyway. I have always had them prior to the Roadster so I'll suggest that. It may be that all will be well but I think that my friend is now wary. Thank you to all of you who chipped in with ideas.
meabh #714598 17/08/21 08:26 PM
A CTEK or similar battery charger is the answer if the car regularly stands for extended periods.
Costock, UK
Disco 5
meabh #714599 17/08/21 09:03 PM
An alternative solution is as you suggest Ian fitting a battery isolator (red) switch which I have had or have fitted myself on my three cars over the 17 years of ownership and have never put a charger on any of them.
The longest I have left my Plus 8 dormant due to a long holiday was 10 weeks and she fired first pot up.
I would never feel comfortable without a battery isolator switch in a Morgan but that could be due to a lifetime of working with electronics and seeing the resultant battery explosion due to a top quality battery charger failure on standby generator plants on one of the radio stations I commissioned.
Float charging is out of the question for me, but each to his own as they say as I have said previously on here.
