6 members (AlyMatt, TrickieDickie, IcePack, David_E, PaulJ, DaveW), 268 guests, and 91 robots.
Topics49,849
Posts837,410
DazMog, The Impaler, tlchzj79
Anything with this as a base molybdenum disulfide. The original lube was called Dri-Slide and it was developed in conjunction with the U.S. Military, especially Air Force , for machinegun lubricant. It was not good having guns jam in a location that was not possible to clean in flight so this stuff was developed to not attract dirt, dut, sand, etc.
DriSlide
There are probably other sources for less money.
This is a similar joint venture that BreakFree had with the military to develop a lubricant that could break up blackpowder residue in cannon(blackpowder was/is used as an initiator for the smokeless powder loads in cannon. Don't use it on cables, but it is great in other applications that corrosion might be starting.
thanks, Stephen. Noted, on my list for garage. I use this to break seized and rusted bolts and nuts...readily available in the states. secret is: "spray, walk away." after about 30-45 min it will work its way through.
end user
I also use that, and it is good fo the air tools as well.
