Topics49,847
Posts837,389
Posts: 8 |
Hi, did anybody has some experience in buying and installing (LED) signal lights which are transparent for the new Plus Four/Six? thanks
Posts: 8,667 Likes: 408
Posts: 8,667 Likes: 408 |
Not sure what the CX cars have as standard but if the usual 21watt filament bulbs with BA15s base, these from Classic Car LED's should work and not upset the Canbus. As the light emitted is amber they will work behind clear len's.
Posts: 8 |
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
They are a full OE lampset that's LED cluster in the backplate, so not replaceable bulbs as Richard's post above, so if you change the cover it will perhaps flash 'clear / white'
Posts: 8 |
thanks CooperMan… anybody else tried to source and change signal lights - transparent?
Posts: 8 |
Posts: 13 |
Tracked down and spoke to the Supplier as they are made purely for MMC. So until someone produces a Clear unit and Amber LED, I rear the answer is - no.
Plus 4 in Claret Red 3.7 Roadster Crystal Blue Plus 4 in Lapis Blue Plus Four inPalladium Silver
