6 members (B3MOG, Strathaven, BobtheTrain, Simon, BLUE+4, Joske Vermeule), 140 guests, and 42 robots.
+8Rich 82
Topics49,859
Posts837,498
Jonny72
Robbie #8520 27/09/07 10:20 PM
Originally Posted By Robbie
Lorne,
Emerald Isle is lovely and sunny to-day and forecast to stay this way until next Tuesday at least!!!
Robbie
Dammit! You have made our lives confusing. We ferry the channel tommorrow with Spain in our sights.
Lorne & Audrey (who LOVE Ireland)
gomog #232904 07/11/14 11:20 PM
Originally Posted By gomog
Originally Posted By Ponapay
What a marvellous help, many thanks I will investigate further.
One further question however - how do I flush the system?
Hi,
Forgive me for possible overkill..but I have found it always best to give a complete explanation than a short and sweet one.
Automobile hydraulics (clutch and brake) use special fluids. The different types are designated as DOT 3, DOT 4, DOT 5 and DOT 5.1. DOT 5 is silicone based and the rest are borate ester based. (The higher the number the higher the boiling point.) DOT 5 is NOT compatible with the others and switching to and from DOT 5 can cause grave problems. Avoid DOT 5 like the plague. However, once used, you must continue to do so. You cannot safely switch back without changing every bit of rubber in the system.
All brake fluids are designed to resist the absorption of water. That ability fades over time. Brake fluids (in clutch or brakes)should be changed once every 2-3 years depending on how damp your climate is.
Lorne
Hi Lorne, I apologise for this being my first post and don't want to appear to be coming on here waving a big stick at anyone.
I browsed through the rest of this topic briefly and found that no one picked up on a point you made about brake fluid being designed to resist water but this information is inaccurate.
All brake fluids discounting the silicone Dot 5 are Hydroscopic and absorb moisture from the atmosphere, When this happens, the moisture in the system can heat up and evaporate as we are continually using the brakes/clutch. The only thing left in the system to replace the evaporated moisture is air, as air is compressible, it renders the system inefficient and tell tail signs at the pedal indicate this. With a brake pedal, it becomes spongy, (with a servo assisted system, the spongy effect is only noticeable if the vacuum is exhausted) with a clutch, it effects smooth gear changing. Hydroscopic fluids also contaminate the system as moisture increases and begins to corrode the internal parts of the system. This is the reason we change the fluid in our systems periodically.
http://en.wikipedia.org/wiki/Brake_fluid
Vehicle restoration since 1986, here to help if I can
Ponapay #232954 08/11/14 09:38 AM
Not hydroscopic - hygroscopic... smile
Otherwise, absolutely agree...
Oh, and welcome to TM! thumbs
Ponapay #233002 08/11/14 12:38 PM
Change the fluid every 2 years...do clutch and brakes at same time.
Hygroscopic nature means it will deteriorate.
From your description of the pedal travel and " bite" point a fluid change is the best first option.
Persistent problems could then be master/ slave cylinder servicing needed.
Also.... check the gear remote for function. There could be rubber bush wear or even the " dust cap" over the lever issues. See Gomog site workshop manual for details.
If all these fail then it's the BIG JOB - clutch out to check/ repair!
cheers
Hi Graham, couldn't remember the name but in the wikipedia link within my post it mentioned hydroscopic surrender I just checked the term hygroscopic, I'll remember it in future. laugh2
Cheers
Ponapay #233611 11/11/14 08:12 AM
laugh2
No worries Paul, just the pedant in me.
I often see it written incorrectly. Wikipedia is only as good as those adding information.
Looooong time since I was in Perth... 1992, shocked2 wonder where the time has gone...
Ponapay #715239 23/08/21 07:51 PM
Researching clutch pedal issues on the web has led me to this thread which is much appreciated so I’d like to take the opportunity to thank the contributors, and of course Simon for keeping it all going thumbs
06 Saab 93
Ponapay #715981 29/08/21 01:40 PM
It may be worth checking the gearbox bias, my spring had broken making selection of 3rd & 4th gears difficult
1999 Morgan Plus 8. 3.9 ....
1961 Alvis TD21 Series1 3 Litre Auto....
