Topics49,848
Posts837,403
Posts: 218 Likes: 5
Posts: 218 Likes: 5 |
Had a great run to Plymouth and across the ferry to the Finnygook Inn in Crafthole on Monday - really good food in good Morgan owning company, then a fabulous drive back the "long way" around the edge of Dartmoor via Launceston. ![[Linked Image]](https://www.tm-img.com/images/2021/08/25/image0.jpg)
Ken Current 2003 +8 35th Anniv. Model 2014 Porsche Boxster GTS Previous 1996 Jaguar XJS Celebration
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
See? Silver alloys look amazing.  Yep
Posts: 37,408 Likes: 977
Posts: 37,408 Likes: 977 |
Nice run out to the Royal Seven Stars in Totnes for dinner with friends, just perfect weather, company, meal and a pint of Tribute. What could be nicer than burbling along on a warm summers evening
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
Sounds lovely. We did a run to Pulham Market near Diss and had lunch at the Falcon. Timothy Taylor's and Fulkers London Pride on hand pull plus steak and ale pies.
That sounds great John, Timothy Taylor's is a handsome pint, were you out with the gang or with the good lady.
Posts: 6,667 Likes: 433
Posts: 6,667 Likes: 433 |
Been blatting around the North Wales countryside, and did the EVO Triangle (although all within the speed limits due to numerous average speed cameras). Nice trip to Bodnant Gardens yesterday, and spotted this beauty in the carpark (110 Anniversary Plus 4). ![[Linked Image]](https://tm-img.com/images/2021/08/26/IMG_20210825_125942.md.jpg)
Posts: 1,982 Likes: 103
Posts: 1,982 Likes: 103 |
What happened to the hood on the passenger side ??
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Mine does that if you don't get one side in perfect when you tension the back it jumps out.
Posts: 8,667 Likes: 408
Posts: 8,667 Likes: 408 |
I was given the advice by Allon White's trimmers to ensure both over centre catches were in position but not tensioned initially when fitting top rail. This avoids to a degree the situation were one catch is tight on tensioning and the other less so due to poor lateral alignment.
Phil from Allon White does a good video on this, which I found very helpful https://youtu.be/bfqxH_i-gLwI had to adjust the over-centre catches on mine, an easy fix, one was a good two turns off when I got the car.
