Topics48,338
Posts812,948
Members9,203
Posts: 2,396 Likes: 14
Posts: 2,396 Likes: 14 |
Thanks for posting Craig, most interesting!
1969 4/4 1995 plus 8 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 1,075 |
Belt is inside the cam case clean and dry running at 180 degree, same as oil temp. How many of you guys have an oil temp of 180 after warmed up?
Dan
Posts: 711 Likes: 8
Posts: 711 Likes: 8 |
Belt is inside the cam case clean and dry running at 180 degree, same as oil temp. How many of you guys have an oil temp of 180 after warmed up? That’s why we needed the spacers between the cam cover on our M3W’s to keep the belt alive. For Craig thanks for posting 👍
Posts: 3,854 Likes: 2
Posts: 3,854 Likes: 2 |
Belt is inside the cam case clean and dry running at 180 degree, same as oil temp. How many of you guys have an oil temp of 180 after warmed up? 👍👍👍👋👋👋👋👋👋 oil cooler
Posts: 212 |
this article confirms some things everyone says, the 2000-3000 rpm cruise speed for lower vibration, for one. Oil temp issues: "Oil giving up at high temp." Not sure about the crank hsp figure...or how that translates with the various drives used on the 3W. 800 hour test at 3200 rpm? I wonder if Morgan tests its gear like that? I like the factoid, four V twins the size of the x-wedge would make a 557 cubic inch V8. "Elegant simplicity" is not what I think when I fire this thing up and open the throttle.
end user
Posts: 2,140 Likes: 43
Posts: 2,140 Likes: 43 |
Belt is inside the cam case clean and dry running at 180 degree, same as oil temp. How many of you guys have an oil temp of 180 after warmed up? I would say that 180f (82c) is about what my engine runs at after fully warmed up most of the time, on an 20c ambient day. No oil cooler involved but that is in a generally cooler UK. I think the problem with cam belt failure was heat soak in the same area of belt from the crankshaft, as it usually stops in the same position. The extra ventilation must help keep things within the allowable range for the belt. A good article, thanks for sharing it Craig.
