7 members (Hamwich, Montegue, DCH, BLUE+4, nick w, TBM, Bishmog), 268 guests, and 49 robots.
John V6 74
+8Rich 68
DaveW 67
9,203 Registered Users
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Goggle eyed
by Roady - 19/07/25 06:16 PM
Topics48,340
Posts812,967
Members9,203
PPP356
Thanks for posting Craig, most interesting!
1969 4/4
1995 plus 8
2002 Aero S1
2013 M3W
2014 Plus 8
Belt is inside the cam case clean and dry running at 180 degree, same as oil temp. How many of you guys have an oil temp of 180 after warmed up?
Dan
That’s why we needed the spacers between the cam cover on our M3W’s to keep the belt alive.
For Craig thanks for posting 👍
www.m3w-jungfrau-treffen.com
👍👍👍👋👋👋👋👋👋 oil cooler
this article confirms some things everyone says, the 2000-3000 rpm cruise speed for lower vibration, for one. Oil temp issues: "Oil giving up at high temp." Not sure about the crank hsp figure...or how that translates with the various drives used on the 3W. 800 hour test at 3200 rpm? I wonder if Morgan tests its gear like that? I like the factoid, four V twins the size of the x-wedge would make a 557 cubic inch V8. "Elegant simplicity" is not what I think when I fire this thing up and open the throttle.
end user
I would say that 180f (82c) is about what my engine runs at after fully warmed up most of the time, on an 20c ambient day. No oil cooler involved but that is in a generally cooler UK. I think the problem with cam belt failure was heat soak in the same area of belt from the crankshaft, as it usually stops in the same position. The extra ventilation must help keep things within the allowable range for the belt.
A good article, thanks for sharing it Craig.
