5 members (+4competion, jbk, Mogdavid, AndyGoff, rossocorsa), 216 guests, and 84 robots.
Topics49,847
Posts837,387
Page 6 of 6 1 2 3 4 5 6
I would hazard a guess that the sleeves need to be floating to sit correctly when adaptor torqued up.
As I understand it (apologies if wrong) the "solution" is to fit loose sleeves to bolts that hold adaptor to bolt on wheel hub to better match adaptor hole size. Not a spacer as such therefore.
No ... but ... if, as I understand it, the splined hub adaptors involve bolting a plate/disc (whatever it is that carries the splined hub) to the face of the existing wheel fixing/hub, then, by definition this must be spacing the wheel further out - just like boy-racer wheel spacers of yore? This would then place an "off-centre" load on the wheel bearings, would it not? Just saying ... innocent
Nick
Depends on the wire wheel offset I suppose Nick. I would have thought it needed to leave the tyre in similar position to ally wheel option for mudguard clearance.
