1 members (+8Rich),
262
36
Topics49,897
Posts838,017
Posts: 21 |
Hi there,
at the moment I am on the track of my sporadic idling problem (plus 8 '93 CUX14). Sometimes the engine runs too fast at the traffic lights. Some days everything is ok.
I checked the electrics of the speed signal (many thanks to Mike (teknome) for sending me a circuit diagram!) Then I built an adapter that allows me to access the engine control unit with rovergauge.
Everything looks good, even the stepper motor can be controlled when it is removed.
I have come to the assumption that a sporadically failing mechanism of the stepper motor could be the cause.
After cleaning the sealing surface and a few drops of WD40 on the mechanics, the first test drive was successful. But how long does it last? I would like to swap the stepper motor.
Now I've read a lot about poor quality spare parts. Has anyone had a good experience with a particular supplier?
Greetings from the Sauerland (Germany) Günter
sorry for my bad English but school's out for many years
Life is too short to drive boring cars!
Posts: 37,480 Likes: 989
Posts: 37,480 Likes: 989 |
Gunter, I have bought other parts from this firm and they have been as advertised and these prices seem to reflect a quality product. There are other suppliers from £22 but I wouldn't waste my time with those tbh. Good luck.
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
I bought my Stepper Motor, Fuel Injectors and a few other bits from Mark Adams at: www.tornadosystems.com
Posts: 102 Likes: 1
Posts: 102 Likes: 1 |
I had a similar problem on a 1997 +4. The stepper motor rotated a cam which pushed a brass pin which opened the throttle, the pin would stick. After a good clean the problem was solved and didn’t reoccur, but it did take me 3 months to discover this after changing sensors, trying a different ECU ………..
Tim Plus 4 2018
