Topics49,904
Posts838,076
Posts: 343 |
i noticed a difference in wheel base on my '89 +4 ( M16 ) but , as far i can see, all seems OK , nothing loose or bend , all in place as should be.
Now i wonder if the centering bolt in the leafs ( 5 leafs here) is indeed in the center between the spring's bolt holes ? And are the bolt holes the same both sides , so that a spring can be mounted wrong ( front/rear) which results that the centering bolt is not in the same position left and right ?
Many thanks for info !
2004 GTN #5 sold 1989 Plus 4
Posts: 2,095 Likes: 75
Posts: 2,095 Likes: 75 |
Could also be the front crosshead out of kilter? Guess you will be taking some reference measurements to identifiable points on the chassis to confirm where the problem lies.
Posts: 343 |
thanks Doug for reply . We see it clear : left rear wheel is more up front then the right one. I measure almost 10 mm. At the base plate of the leafs i measure around 5 mm difference... as if that centering bolt ( seems intact , no damage ) is 5 mm more up front compared the right side.
Posts: 1,415 |
The locating pin is offset not on centre
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 343 |
thanks Simon !
that can explain the difference i have.... the right side leaf spring must be installed ( PO ? factory ?? ) the wrong way. At least what i suppose, as the right rear wheel is much better in center fender.
PS strange , i searched some topics about installing leaf springs , but never seen mentioned that the locating pin is off center ... so those springs do have a mounting direction. Perhaps it is labeled on new ones ?
Posts: 6,676 Likes: 441
Posts: 6,676 Likes: 441 |
I think if it's between 5 and 10 mm difference it's not that a spring has been fitted wrong. If you have a look at the photo below there is far more than 10mm difference. Personally I don't think it would be possible to successfully mount the axle if one spring was reversed? The top spring is the newer 4 leaf rear. When fitted to my '72 4/4 it re- centered the wheel perfectly in the arch - moving the axle back about 25mm. ![[Linked Image]](https://tm-img.com/images/2021/09/07/uj4fEBuGk0v8O1mGXVPbYBEWfrO7_fTzRGZVC0E8Icu-tkHWK0hmSwnHE1rSE_kua3IC0nEXJVcbmaimoixoztDGToTD3yAwtiD6zLly_oysi2XBhqVhjynAuer0K_i-ZKADQPD2-LP-tLWB5S3It7hySXO5zTbqMt8BX0naIuMzDpIYFixkLbfgHZ98uNEx8uj24xwM.md.jpg)
Posts: 343 |
TBM , i can be that the difference with older versions is greater , indeed perhaps to get the wheels better centered in the arch at some year in the past . That is a '72 , mine a '89.
Now if those more recent springs only differ due 5 ? mm offset of the locating pin , i think it is possible to mount them ( one ) wrong ?
PS i also checked the rear spring shackles , no play and both at the same angle ( no length difference )
Possibly - the top springs are a generic 4 leafs that fit 1969 up to (not including) the CX version. However I remember when I fitted them it was very obvious which way they went - there was a significant difference in the distance between pin and eye either side.
Posts: 343 |
as the car is sagging on his springs too i think it's not worth the work involved to change that spring in direction....so i asked price at our Morgan dealer for 2 new springs and option install at the shop. I could do it myself.... but perhaps they have the "routine/special tools " and can do it for a fair price.
It is a fairly straight forward job, and easily done by a competant home mechanic. Does takes a failry long time, which may influence the price from the Morgn dealer. Parts cost me about £350 for the springs, about £60 for new U bolts, and £30 for new bolts and spacers.
