4 members (hillclimber, CharlieB, MATTMOG, gomog), 199 guests, and 32 robots.
+8Rich 94
John V6 50
Posts837,997
rockabilly john
Page 4 of 5 1 2 3 4 5
DaveW #67344 30/08/11 04:16 PM
Dave, did you keep with the sticky tape for your clock.
I have found that the tape I have, which has successfully held rubber trim etc, fails when the car gets hot , whilst parked. My carefully aligned (black faced, black surround) clock now sits 5 or 6 mm lower than its optimal spot having slipped on the tape.
Is there a secret?
before I get the drill out
sawman #67349 30/08/11 06:06 PM
So far it's stayed put, but hasn't been in direct sun. The tape I used is from Halfords with a green backing. It's black tape, and wide, but quite thin. When I use it on the rally Plaque holder it lasts easily over two days and takes some shifting. I also use it behind my leather fripparies, and nothing has dropped off yet, so I'm optimistic.
DaveW #67350 30/08/11 06:22 PM
Cheers Dave, I'll check out halfords before I fire up the black and decker
sawman #67352 30/08/11 07:19 PM
If you really want it to stick, bathroom mirror tape will do the trick; however, be warned, once stuck down, it tends to stay in place. I use it for my registration plates and they have been known to crack before I can get them unstuck from the car. A small piece would do the trick but as I'd only use it as a last resort before the drill. wink
Simon #67356 30/08/11 08:48 PM
I use industrial strength Velcro. The. Lock has stayed put!!
Cheers!
Robbie
2021 Plus Four -- Helga
211-WX-1433
Robbie #67357 30/08/11 08:50 PM
That should have read " the clock" stays put!!!
Robbie
211-WX-1433
DaveW #67404 31/08/11 02:50 PM
That last sentence makes a great quote....... blush
trevmar #71761 31/10/11 04:40 PM
Chuffed to bits with my Chronos clock ... until it stopped working frown. Bought some new batteries, fitted the replacement (fiddly - but easy) - same result.
The seller couldn't have been more obliging - sent a replacement clock by return of post ... which has now also stopped mad
Has anyone else had this problem? I'm so glad I didn't drill the dash to fit the mount (or even worse - cut a hole!). At least if I can't get one that keeps working long term, I've not ruined the dash.
Nick
vincentvg #71836 31/10/11 09:18 PM
Yup , the first one stopped after 3 days, the promised replacement arrived 10 days later after email and telephone reminders.
Kevin
Black/tan 4/4 sport
bulldog #71856 01/11/11 06:31 AM
Mine is still working and still mounted with Velcro!!
Robbie
211-WX-1433
