2 members (ScotiaSteve, +8Rich), 279 guests, and 104 robots.
+8Rich 84
Topics49,860
Posts837,484
#718070 14/09/21 08:43 PM
I have decided to replace the front indicator for a new plastic canister and led light. I already have the black bullet style OEM canister (I know everyone swaps out with aftermarket, but I am too lazy do do all of the them right now). Can anyone help me locate a supplier of this LED light? I think it's this one without the triangular brace.
https://dasteri.gr/en/products/LED-FRONT-DIRECTION-INDICATOR-LAMP-9-33V.151/
end user
Link to Dasteri website here. I would be tempted to use this part from Car Builder Solutions though.
Just need to chop the lugs off.
Richard, is this the same thing? I am assuming this is plug and play in regards to this note: "NOTE. All LED Flashers/Indicators retro fitted to vehicles will need either a special Pulse Generator 01-141 or Two Ballast Resistors DSL MDL 12 – one per side of the vehicle."
http://www.maxparts.biz/index.php/dasteri-lighting/rear-lamps-led/dsl-0400dir12-detail
end user
I think they are the same item. I will add the Dasteri number to the Alternative Parts List, the Car Bulder Solutions number is already there. You won't need the pulse generator as the system will take care of the flashes.
Thanks, Ian!
end user
When I was looking for the OEM Lamps for the rear of mine I came across these. They have it in all colors and doing business with them is good.
https://www.s-v-c.co.uk/product/ultrabright-inner-led-reverse-/
Factory fit is LED indicators Craig. The appropriate flasher is therefore already in place via the TSM module so your concerns are not valid.
FWIW I used the 55mm reversing light variant from same source to provide this feature on my M3W. I also used the same type of plastic pod so know it fits after removing the three mount lugs.
ETA: The Dasteri units you linked to look the same as Car builder solutions ones, even down to the lugs you have to remove. I would suggest either would work fine so it comes down to price and availablity in the USA.
Last year I bought indicator units from car builder solutions, code LED55IND.
I was charged GBP39 ex vat for a pair.
I also got a single unit from MMC for more than that !!
Pays to shop around
Maxparts informs me that they'll sell the original part they sell to Morgan for 60 bucks (won't need to be modified), I will share info on ordering...I'm assuming I won't need to drill a hole to include the screw that Morgan adds to the assembly of this in the canister? Not sure ho susceptible to engine vibration or why they use the tiny screw?
end user
The maxparts reps are charging me more but they answer their emails promptly and are courteous.
end user
