1 members (MOGDave),
305
Posts837,990
Posts: 516 Likes: 1
Posts: 516 Likes: 1 |
Friend with a 1993 Plus 4 T16 engine wonders if anyone knows what clutch assembly was used by Morgan, either a part number or alternative vehicle would help?
Thanks
Malcolm
Malcolm T 1966 +4 1957 TR3 1963 TR4 1983 LR 110 1985 Robin Hood 2.0l
Posts: 27,835 Likes: 760
Posts: 27,835 Likes: 760 |
I would assume the rover clutch as it has the rover gear box.. i think from the rover 820 model
Posts: 516 Likes: 1
His worry is that the Rover application was transverse mounted and the Morgan is to an LT77. Gomog site says that it is the same clutch as the +8, but another source says Rover 800/820.
Was wondering if anyone had done the job and knows for certain
Thanks
Malcolm
Sorry I havent
I'm sure BHM would tell you
Posts: 516 Likes: 1
Maybe that's what he needs to do (ring BHM). I had looked on the BHM parts site to see if they list a clutch kit, hoping to see whether the +4 and +8 kits matched, but they only list a +8 kit for a 4 speed box, and don't list the T16 kit at all as far as I can see.
It's not urgent but one of those jobs that will need doing in the not too distant future, so he's trying to research the options.
Thanks again
Malcolm
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
Clutch out and down the local motor factors with it for positive identification
A good factors should be able to order up a clutch kit the same day/next day
Arwyn
Posts: 1,415 |
Thanks again
Malcolm I’ve got one on the shelf at the workshop Put him in touch with me and I’ll sort him out
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 1,149 Likes: 19
Posts: 1,149 Likes: 19 |
Please take photos of the clutch replacement, I'm particularly interested in the thrust bearing etc as I have an occasional squeak when engaging/disengaging the clutch. Also on idle I have a slight rumble in neutral again a possible bearing issue
Morgans 1934 MX, 1947 Series 1, 1956 +4 TR4, 2000 +4 T16 Triumph Herald 1969 13/60 Morris 1970
