5 members (Fuel.inj, Rudolf, Grumpy2, Hamwich, IcePack), 294 guests, and 37 robots.
+8Rich 102
John V6 64
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,218
MossyfromNZ
#719532 27/09/21 02:52 PM
SALMO Offline OP
Hi Everyone,
Last weekend I shot at a few clays and as is my norm cleaned and oiled my shooting implement when I got home.
For years I’ve followed the same procedure ending with a light oiling of the metal bits and beeswax on the wood.
Now here’s the thing, I never get oil on the wood since eventually it will blacken and go soft.
So, what danger to our cars’ wood when lubing the beading strips?
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
None as far as I know
Formerly known as Aldermog
The Morgan wood is ash, not something used when crafting a fine shotgun, I feel. Wood for a gun stock is often walnut, or something similar.
The Morgan ash frame has already been soaked in cuprinol and white spirit.
I suspect that light machine oil will keep the wood waterproof and discourage corrosion in the adjacent metal. Even so, I use ACF 50 when I "oil the beading".
I've always been happy enough to carry out the instructions in the MMC car handbook to use a light machine oil and I choose 3 in 1 as it has a plastic not scratching spout and is a handy sized container.
No reason to doubt the factories wisdom on it's usage really.
This might cause some controversy. I used to use 3 in 1 oil on my beading, but got told to never ever ever use it as it rots rubber, a should be using a natural oil. I've switched to using Danish oil as I have a good amount of that. My handbook recommends a light oil as opposed to a light machine oil.
2004 Series 1 Roadster
Danish oil, though good as a wood finish, is a hard drying oil so I question whether it is the right thing to use bearing in mind the flexibility of the Morgan chassis and tub. Think a better choice would be a silicon based oil which is produced by 3 in 1 and others.
As far as damage to rubber is concerned, it all depends on the formulation of the “rubber” component. Just try finding that out!
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Natural rubber is affected by mineral oils. The self sealing tanks of spitfires etc had a natural latex rubber called Linatex in a layer around the fuel tank. If a leak occurred due to a bullet hole the latex expands and seals it.
htts://www.global.weir/newsroom/news-articles/five-unconventional-applications-where-linatex-rubber-stands-the-test-of-time/#:~:text=Famously%2C%20Linatex%20%C2%AE%20rubber%20was%20used%20to%20line,it%20prevented%20fuel%20leakages%20and%20the%20resulting%20fires.
The rubber beading on the mog will be a synthetic rubber that isn't affected by mineral oil.
ACF 15 is the stuff to use. It is supplied to the aviation industry so it is safe for Morgans. It's around £15.00 for an aerosol and avaiable from most motor bike shops.
Reg
On a similar note, does anyone actually lubricate their spoked wheels ?
Mine are stainless, but I recall seeing specialists apparently offering stove-enamelling and painting services, surely that locks the spokes solid ?
Everything you ever wanted to know about wire wheels is here: https://www.truespoke.com/frequent-wire-wheel-questions
HJF Offline
I re-beaded our Caterham when I rebuilt it. Seem to recall it was a PVC like material. Car has gone now but I think I still have an offcut in the garage. If I can find it I will do a soak test on some samples to see if it’s affected.
