Topics49,878
Posts837,744
Posts: 1,103 Likes: 2
Posts: 1,103 Likes: 2 |
Folks,
Anyone know where the earth connection is on a 2002 4/4 (Zetec black top). I want to check out the connection but could do with a pointer as to where to start to find it.....
Also trying to find out where the earth return from the fuel pump (disappears into rear loom) ends up..
Keith
Car 54 - 'Le Mans 62' 4/4 Supersport OxMog Member (and associated with CranMog and SwanMog)
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
There's a group earth connection at the rear offside of the chassis Keith. Adjacent to the spring shackle. That will include the fuel pump.
Check under the passenger footwell and under the master cylinders at the front.
Is that to the front of the spring? From what I initially saw it appears that the loom runs along under the parcel shelf and dives down under the 'sill trim' and assume out through bulkhead. So assumed earth wire used the same loom..
I will recheck, thanks
Keith
Posts: 27,822 Likes: 749
Posts: 27,822 Likes: 749 |
Keith, I expect it is pretty similar to a Roadster. Here is the link to GoMog. EarthsEven if the earths look good my advice is to dismantle & clean with contact cleaner. John
