10 members (Willowgreen320, Hamwich, Alan Patterson, MATTMOG, sewin, RobS, Rog, High Hamster, stumog, Morganmike),
251
52
Posts837,969
Posts: 27,833 Likes: 758
Posts: 27,833 Likes: 758 |
Do you not have a separate supply for front spots and an unused switch location on the dash? Talk to BHM they were great helping me with my start button.
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
Do you not have a separate supply for front spots and an unused switch location on the dash? Talk to BHM they were great helping me with my start button. I will check on the wiring but no spare switch as I have aircon.
Posts: 132 |
I am thinking of fitting a pair of spot lights, Ionly want them to work when on main beam so can I connect them directly to the main beam feed or do I need a separate feed through switch and relay Definitely use a relay. I burned out the lighting stalk contacts trying something similar.
Thanks for all the helpful comments
Posts: 8,695 Likes: 415
Posts: 8,695 Likes: 415 |
Keith, just been looking at the +4 wiring schematic for your car. Wiring is already in loom for front fog lights (look for unused blue/yellow cables under wings). These lights are controlled via an optional dash switch, plug with two wires for which should also be present (red/orange and blue/yellow).
It seems therefore much of the fresh cabling could be avoided by using existing and adding factory switch although you would still need to intercept and add relay for main beam only operation.
Posts: 1,707 Likes: 35
Posts: 1,707 Likes: 35 |
Has anybody found a power supply that is only alive when the engine is running, it only needs to be suitable for activating a relay. Interesting requirement! Could an optoisolator connected in the ignition lamp circuit work to drive a relay?
Roger 2011 Plus 4
It seems therefore much of the fresh cabling could be avoided by using existing and adding factory switch although you would still need to intercept and add relay for main beam only operation. Thanks Richard
