2 members (sewin, Tony Quinn), 274 guests, and 51 robots.
+8Rich 90
Luddite 50
Posts837,962
Do you not have a separate supply for front spots and an unused switch location on the dash?
Talk to BHM they were great helping me with my start button.
Black Rat
Black Rat
I will check on the wiring but no spare switch as I have aircon.
Keith
2013 narrow bodied + 4 Ruby.
I am thinking of fitting a pair of spot lights, Ionly want them to work when on main beam so can I connect them directly to the main beam feed or do I need a separate feed through switch and relay
Definitely use a relay.
I burned out the lighting stalk contacts trying something similar.
Black Rat
Black Rat
Thanks for all the helpful comments
Keith
Keith, just been looking at the +4 wiring schematic for your car. Wiring is already in loom for front fog lights (look for unused blue/yellow cables under wings). These lights are controlled via an optional dash switch, plug with two wires for which should also be present (red/orange and blue/yellow).
It seems therefore much of the fresh cabling could be avoided by using existing and adding factory switch although you would still need to intercept and add relay for main beam only operation.
Rog Offline
Originally Posted by CPN
Has anybody found a power supply that is only alive when the engine is running, it only needs to be suitable for activating a relay.
Interesting requirement! Could an optoisolator connected in the ignition lamp circuit work to drive a relay?
Roger
Black Rat
Black Rat
Thanks Richard smile
Keith
