3 members (RichardV6, Stevo666, ScotiaSteve), 216 guests, and 42 robots.
Topics49,860
Posts837,488
Jonny72
Page 3 of 3 1 2 3
Reiver, when I did my earths on the 4/4 a few years ago I bought the wires from Halfords. Measured the lengths needed and bought them. They are designed and made to a standard and cheap enough. When fitting them I cleaned contact areas, used stainless bolts and smothered the connections with petroleum jelly.
I applied the KISS principle!
The reason that engine to chassis earth leads are braided is that they require to flex. If you use anything less flexible than braided, you risk failure at some time, if not creating unwanted vibration passing from the engine and into the chassis and beyond..?
Online NoMood
Originally Posted by Reiver
I thought the battery earth to chassis braided strap looked a bit puny but then I'm used to bigger and more modern battery setups. The chassis stud the earth connected to was pretty corroded and I don't think it would survive an attempt to undo it. It worked well enough for the test I did.
I couldn't get under the car to comment on the gearbox earth. I couldn't see any earth strap around the starter motor area but the advice to run an earth from the upper starter mounting bolt to the chassis seemed a good idea.
Of course I forgot to check the size of the bolts - 17mm ?
Getting ready made cables seems somewhat difficult so I thought I'd invest in a crimping tool (Draper 64335 Crimping Tool) and make my own.
What size cable would you suggest? 16 or 25mm ? Since this is an additional earth I thought the 16 would be sufficient.
I intend to put a longer (M10?) bolt through the starter/bellhousing and connect a right-angle ring terminal onto the end with a locknut to secure it. The other end would be an M8 ring terminal secured to the chassis brace below the bulkhead.
At least 25mm2, better 35. You will always gain to some degree (however small) with the larger cross section. The tiniest resistance magnifies the power (i2r) loss by the square of the current it carries remember. Consider the equivalent cross section flat braid for earth connections between components that move or vibrate with respect to each other.
Page 3 of 3 1 2 3
