9 members (Fuel.inj, Vansrv6, bmgermany, RichardV6, Alan Patterson, GrumpyPa, JohnHarris, TBM, Hamwich), 183 guests, and 86 robots.
+8Rich 77
Topics49,870
Posts837,669
Rudolf
Image #721546 14/10/21 04:13 PM
Image Offline OP
Cheers Andrew ..... will try it with no cable slack .... doesn't feel like it's far away so that may be enough ... though I must admit to always being wary of loading the throwout bearing and it wearing out because it's constantly turning ... however, as a test to see just how near the clutch is to freeing completely it should be fine .... if it's close I can juggle with the various adjustmemts to find it.
Did you find the throwout bearing lasted ok on your 4/4?
Image #721576 14/10/21 07:06 PM
Hi again
My first experience was with Escorts, crossflow engines and cable clutches. Very similar set-up to my 1978 4/4 with 4 speed box. Followed article in Miscellany to convert to 5 speed Sierra box.
All clutch adjustments followed same guidance, which is detailed in Escort Haynes manual.
Sold the 4/4 in 2000, but still know the car, which is on the same clutch renewed at gearbox change.
Hope this gives some confidence
Andrew
Image #721582 14/10/21 08:09 PM
Image Offline OP
Cheers Andrew ... will give it a go tomorrow.
Would still be interested in the clutch lever movement measurement if anyone out there has one.
Image #721601 15/10/21 02:05 AM
My clutch has oft times been found to be stuck, due to lack of use, sigh ! Just a case of warming the engine then jacking the rear wheels free of the deck, starting the engine in gear, and using the brakes to break the bond betwixt driven plate and the polished faces of the flywheel/pressure plate.. using a bit of heel and toe. Marginally brutal but a tad easier than removing the engine to get in amongst things..? Once freed off I polish the faces by slipping the clutch just a little... Works every time. So far..(-:
I appreciate that this may not be related to your issue K, but just thought to throw it in to the mix lest it might be the issue for some reading this thread.
Image #721603 15/10/21 04:53 AM
TBM Online Content
Simon has retained the rod linkage on my conversion. I'll take some photos at the weekend, including position of the arm.
Image #721607 15/10/21 07:54 AM
Image Offline OP
Luddite .... I had considered that the new plate might have stuck to the flywheel .... the clutch change was one of the first jobs I did, so it's been sat for the best part of a year while I rambled through other bits of the rebuild ... will give that a try.
TBM many thanks for the impending pics and measurement. The more info the better when it comes to fault finding.
Image #721619 15/10/21 10:59 AM
K, you caught me out, I had thought you had already driven your 4/4 minus wings etc and found the clutch to be dragging somewhat....!
I bet you a fiver it the driven plate is just stuck... I have suffered this on occasion after a few months on non-usage in our climate.
Image #721621 15/10/21 11:53 AM
Sorry to contradict but if the clutch plate is stuck to the flywheel, you would not even get it into gear with the engine running.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Image #721624 15/10/21 01:07 PM
Image Offline OP
Deejay .... that's the issue .... hoping it's just that and it unsticks without major surgery ..... been in Portugal for a bit and catching up with essential country chores since .... will try it this aft and report back.
Image #721626 15/10/21 01:32 PM
Sorry, when you referred to the clutch not “fully” disengaging when going for a trundle in your original post, I took that to mean you were suffering clutch drag or creep.
My neighbour’s MGB suffered a stuck clutch recently after a long lay up and it was overcome by the jacking up and braking method. Good luck.
Doug
1958 Triton 650
