Topics49,860
Posts837,491
Posts: 159 |
This was missing when I found the car (1974 4/4) and I'm assuming that some marine ply-wood with epoxy will suffice - assuming I can get the right thickness.
I noted some older posts out there where people seemed to be creating additional shelves between the battery location and the parcel shelf and I was wondering if anyone has completed a project like this for a 4/4 and has photos and feedback to share on what they did ?
Thanks
1974 4/4 2 seater
Posts: 1,065 Likes: 23
Posts: 1,065 Likes: 23 |
I think you mean a tooltray. There are a lot of post, one is here: http://www.talkmorgan.com/ubbthreads.php/topics/658734/1Greets René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
Thanks I've made three tool trays. The first in plywood, screwed and glued. The second mainly from a single sheet of aluminium, with sides added and a box to take the difference casing. (Not the best method) The third was made up of a number of shaped aluminium sections riveted together. This one created the most space, but the plywood version is a much easier build.
Posts: 12,257 Likes: 317
Posts: 12,257 Likes: 317 |
I made a tool shelf using exterior grade ply and standard 40 x 12 pine strip from B&Q. Nothing fancy but dead easy to make and does the job fine. ![[Linked Image]](https://www.tm-img.com/images/2017/08/31/IMG_0913.jpg)
Posts: 27,811 Likes: 749
Posts: 27,811 Likes: 749 |
PM me I have design drawings for an ali tray but for the wide bodied cars so you might need to reduce the width.
Posts: 8,675 Likes: 491
Posts: 8,675 Likes: 491 |
I made a tool shelf using exterior grade ply and standard 40 x 12 pine strip from B&Q. Nothing fancy but dead easy to make and does the job fine. ![[Linked Image]](https://www.tm-img.com/images/2017/08/31/IMG_0913.jpg) Looks very neat Tim
Posts: 1,984 Likes: 103
Posts: 1,984 Likes: 103 |
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Posts: 159 |
Agreed - this looks perfect for what I had in mind. I've only taken my Morgan out once. Almost at the point of taking it out again - pending a couple of fixes and I'm very adverse to breaking down without all the stuff I imagine I'll need !!
1974 4/4 2 seater
Posts: 159 |
PM me I have design drawings for an ali tray but for the wide bodied cars so you might need to reduce the width. John, will do - thanks for the offer of the drawings
1974 4/4 2 seater
