1 members (davewhite), 277 guests, and 67 robots.
+8Rich 75
Topics49,861
Posts837,540
Jonny72
#721752 17/10/21 05:12 AM
RobFog Offline OP
This was missing when I found the car (1974 4/4) and I'm assuming that some marine ply-wood with epoxy will suffice - assuming I can get the right thickness.
I noted some older posts out there where people seemed to be creating additional shelves between the battery location and the parcel shelf and I was wondering if anyone has completed a project like this for a 4/4 and has photos and feedback to share on what they did ?
Thanks
1974 4/4 2 seater
X
X
I think you mean a tooltray.
There are a lot of post, one is here:
http://www.talkmorgan.com/ubbthreads.php/topics/658734/1
Greets René
2018 plus4 (sports green)
Thanks
I've made three tool trays. The first in plywood, screwed and glued.
The second mainly from a single sheet of aluminium, with sides added and a box to take the difference casing. (Not the best method)
The third was made up of a number of shaped aluminium sections riveted together. This one created the most space, but the plywood version is a much easier build.
I made a tool shelf using exterior grade ply and standard 40 x 12 pine strip from B&Q. Nothing fancy but dead easy to make and does the job fine.
PM me I have design drawings for an ali tray but for the wide bodied cars so you might need to reduce the width.
Looks very neat Tim
+1
RobFog Offline OP
Agreed - this looks perfect for what I had in mind. I've only taken my Morgan out once. Almost at the point of taking it out again - pending a couple of fixes and I'm very adverse to breaking down without all the stuff I imagine I'll need !!
1974 4/4 2 seater
RobFog Offline OP
John, will do - thanks for the offer of the drawings
1974 4/4 2 seater
This was my third riveted tray.
And my first plywood tray.
