1 members (DJC),
323
44
Posts837,277
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
Not sure how this will go in the U.S.market.... 1962 Morris Traveller
Nice little track day car.... Caterham Super 7
Posts: 215 |
How does that work? A 2002 car with the SV chassis ( which came in late 90s from memory) fitted with a modern engine comes with a registration document and vin plate for a 1967 car. From memory there would be absolutely no part other than the vin plate that would be interchangeable between a 1967 and a 2002SV
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
I'm glad you brought that up Andy as I have just read the advert and surmised it must have been a write off at some stage and the VIN plate was all that remained as those early cars were pretty prosaic but this is a bit of an animal...
Posts: 215 |
In Morgan terms they are as similar as a 1960s 4/4 and and the last of the plus8s ie if you don’t know what it is they look the same sort of shape but little in common apart from that.
How does that work? A 2002 car with the SV chassis ( which came in late 90s from memory) fitted with a modern engine comes with a registration document and vin plate for a 1967 car. From memory there would be absolutely no part other than the vin plate that would be interchangeable between a 1967 and a 2002SV Interesting post Andyrich, thanks for the input
Sorry, couldn't help myself.... 1983 Delorean
How does that work? A 2002 car with the SV chassis ( which came in late 90s from memory) fitted with a modern engine comes with a registration document and vin plate for a 1967 car. From memory there would be absolutely no part other than the vin plate that would be interchangeable between a 1967 and a 2002SV Sold US$44,750.00
