1 members (Graham, G4FUJ),
248
34
Topics49,911
Posts838,152
Posts: 238 Likes: 3
Posts: 238 Likes: 3 |
Hi Recently my original MAF died after about 77000 miles, the original Lucas ones (as far as can tell) are no longer available. I sourced a replacement from FleaBay, the voltage trim screw did absolutely nothing , so it was sent back . I then purchased another(Britpart) one. I set the Voltage to 1.8VDC which resulted in a super rich mixture. I eventually got a second hand one which works fine.
As a result of this I would advise all members to build up a stock of original parts for any defunct engine EFI System.
I have decided to remove the original system & replace it with an aftermarket system, the front runners are :- Canams, Emerald and Megasquirt, so prior to fully committing over the winter, I was wondering if any other members had went down this path and what is recommended & why. I know there will be a power increase but that is a secondary benefit . I also know a lot of criticism around Megasquirt is reliability - if I decide on this,I will be buying from a company that builds the ECU & provides a full kit ,
Thanks for any insight you can provide
Cheers
Alan
1999 Morgan Plus 8. 3.9 .... 1961 Alvis TD21 Series1 3 Litre Auto....
Posts: 1,464 Likes: 99
Posts: 1,464 Likes: 99 |
Was that the one off eBay fit £200? I was looking at that one. I have a cheapo one for the mot. It passes emissions but runs rubbish otherwise so I refit the original one after the mot.
Posts: 238 Likes: 3
I had a friend plug his laptop in and what it was doing was anything but control the fuel mix, it wasn’t £200 just below £100 , the first one was a sand casting ??????
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
Might be worth having a chat to these people before you make your decision. Rover V8 ECU specialists. Tornado Systems
Bob
Posts: 238 Likes: 3
Tornado systems only deals with the original Lucas stuff which essentially 80’s technology. MOTs are not shifting the goalposts but the strictness of enforcement has definitely moved up a cog. The only drawback I have been able to establish is , there’s something going through parliament which is critically looking into “Car Modifications” if you install aftermarket gear on your car such as an ECU ( Brakes, Suspension, Shocks , Panhards, 5 link etc etc ) please refer to :- https://www.gov.uk/government/consu...ing-vehicle-standards#tackling-tamperingBut as long as you don’t use a Morgan Dealer there’s not much chance of them finding the brain. To reiterate what I’m looking for is reviews on the various aftermarket EFI systems
Interesting about those Tornado folks. Only about 30 miles from me. Might warrant a visit…..
Tornado systems only deals with the original Lucas stuff which essentially 80’s technology. Have you spoken to them? I thought they covered the engine right up to later iterations and they also work with standalone aftermarket ECU's. I talked to them when I installed an Omex ECU in my 4/4 but as they specialise in the Rover V8 I didn't go forward with them.
Bob
Posts: 520 Likes: 62
Posts: 520 Likes: 62 |
Alan ![[Linked Image]](https://tm-img.com/images/2018/10/24/IMG_8822.jpg) I got rid of the lucas system from my +8 1985 Flapper,and replaced it with the Canems system ,it is easy to use and you can alter any of the mapping fuel and ignition (Removed the distributor and fitted a trigger wheel and coil packs). have a look at the website lloydspecialistdevelopments. If you want any more information you can contact me and I will try to answer your questions David Byrne
Posts: 988 Likes: 14
Posts: 988 Likes: 14 |
Tornado systems only deals with the original Lucas stuff which essentially 80’s technology. They work with Lucas, Lucas/Sagems and Bosch systems
Brian
Jersey and Spain
I have decided to remove the original system & replace it with an aftermarket system, the front runners are :- Canams, Emerald and Megasquirt, Alan
There is an interesting article by a TVR owner about his journey from moving from 14Cux to Emerald (lots of rolling road sessions required) to GEMS (not for the faint hearted).
Brian
Jersey and Spain
