2 members (Simon, Rastus), 332 guests, and 31 robots.
+8Rich 91
John V6 49
Posts837,985
Originally Posted by RobCol
…and some special tools are required including grinding a semi circle out of the engine mounting so that the timing can be locked with a pin.
That's exactly what my son had to do.
RobCol Offline OP
I thought this was a bodge at first but I should have known Morgan would make things more difficult for us by forgetting to design the engine mount properly!
Rob
Can anyone please advise the ford part number for the Sigma kit ?
RobCol Offline OP
I will see if I can get the part numbers when I have the cambelt kit fitted but that isnt for three weeks. I think the garage had to get the part numbers by using a Ford Focus as a reference as Motor Factors dont seem to be able to cross reference Morgan registration plate or model details.
Rob
I will ask my son tomorrow.
Here is the reasonable prized toolkit from China which did the job well in our case. Original Ford prices could be much higher but I don‘t know. For a ones in ten years job this kit was good enough. It must not withstand a daily job on hundreds of cars.
https://www.amazon.de/dp/B08S7M8KXH...24TVDV11EKAXRH8?_encoding=UTF8&psc=1
All you need from this tool kit are these three parts on the upper part of the box. The tool kit is claimed for somewhat diesel engines but the tool also works for petrol engines, it is the same VCT mechanism.
Hello Guys,
As anyone been able to establish the Ford part number for the Sigma cam belt kit. ???????
Gates KP35669XS Timing belt set incl. water pump
Elring 010.051 Valve cover gasket
Thank you Heinz, very appreciated for this information. cheers
