0 members (), 275 guests, and 97 robots.
+8Rich 64
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,761
Page 3 of 4 1 2 3 4
Leroy Offline OP
Originally Posted by sospan
Re the damper blades fitting. If you do detect front/back movement then it can be adjusted away by adjusting the locating lugs at the chassis. Check these lugs for wear as grooves can form. Cheap to replace with new anyway. Keep the area where the blades enter the chassis end greased to ensure good movement in and out with no unwanted movement. The blades are not expensive to replace either.
When I get the chance I'll have a good look at the dampers. I quickly expected them the other day visually, and could see grease on the top but not sure about the bottom.
2004 Series 1 Roadster
Be careful when you waggle 'em to test for play, the edges can be very sharp
Leroy Offline OP
Well, I checked one of my damper blades this morning and there is a good 3 - 4mm play between the shims fore and aft. Any advice on adjusting the shims? Is it a case of loostening the bolts, closing the gap and retightening them?
Yes I believe that is right. I do not have these but attended Keiths workshop at Brands Hatch Morgan last Tuesday and watched him do exactly this, loosen the bolts and adjust until snug. The blades he showed were in various stages of wear, one set were visibly misshapen at the ends and he advised replacement - apparently inexpensive parts but labour will add to the cost. Keith also showed how to raise the bronze bush with a screwdriver to inject thick oil onto the top of the hub, lightly grease the blade where it moves in its sandwich.
Kevin
2009 Morgan Plus 4 - 4 seater
2015 Subaru Forester 2.0ltr
See here GoMog damper blades
It is easy to do and makes a massive difference.
Leroy Offline OP
Cheers guys. Looks straight forward enough, and hopefully will see a big difference like you suggest.
Richard Thorne once serviced my +4. When I collected it they said there was a steering issue they couldn't trace. Indeed it was nearly undriveable at speed. When I got it home I found they damper blades were totally lose. Problem solved & I changed dealers for servicing.
Leroy Offline OP
Wow. I think you're right to steer clear. I have no issue in a straight line at speed, although I did get moved to the right when I went over a slightly raised part of the road which looked like a stretch of tar, with my left wheels.
Just a thought Leroy, assuming all your tyres are the same 'brand' is the wear pretty equal and most importantly, how old are they from the moulded date code ?
Leroy Offline OP
Yes, all the same brand, and even wear. They are about 10 years old though so could do with being replaced. I expected the ride comfort from them to be not as good as it could be, but could the age effect the steering? The rears are about 5 years old so I was going to wait till next year to replace all round.
Page 3 of 4 1 2 3 4
