1 members (jejemek), 465 guests, and 50 robots.
+8Rich 90
Topics49,841
Posts837,323
Page 8 of 8 1 2 3 4 5 6 7 8
When it fires up it runs as well as normal. I'll check the plug ends tomorrow and report back.
These cars certainly keep you on your toes eh?
2021 Morgan Plus Four
2012 Morgan Three Wheeler
2020 Land Rover Defender 110
The crank position sensor is located on the front of the engine to the lower right of the cam belt cover. Trace the wires back to the connector and disconnect. It is a two pin connector that you can put your multimeter on. Remove the plug wires and crank the engine. The meter should read around 1 volt, if significantly lower, this could be the problem.
2016 M3W
i would check to see if the throttle is returning to zero because if it is slightly open it will not start or start correcty.
