4 members (Morganmike, Moggo, Alan Patterson, How), 266 guests, and 52 robots.
+8Rich 89
Topics49,841
Posts837,326
Christoph
Page 2 of 4 1 2 3 4
BGW Offline OP
Thanks - I think I may need it! Any idea what type / make the fuel pump is?
Brendan
2018 Plus 4
I can't remember all the details now and the invoice went with the car when I sold it.
I think all the information is on the link but Terry should be able to fill you in.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
Pump replacement thinking would come after proving that there was a an electrical supply available to the connector at or near the tank...? Sorry, I have no idea of the set-up on your fuel pump control circuit but generally other than anti theft aspects to the circuit which you seem to have an indicator for that determines all is well...
The fuel pump circuit is likely to have a safety circuit that would stop it pumping fuel out of a broken fuel line in the case of an accident where the driver may be incapacitated and the ign still on. In an attempt to achieve this some sort of switching system may be built into the fuel pump circuit that will only be closed when the engine is running.
As I suggested earlier, my 86 Morgan uses an oil pressure switch to determine that the engine is running, if there is no oil pressure the supply to the fuel pump is cut. Logically there is no oil pressure when you turn the ign key to start the engine, in which case there is a by-pass switching action built in... that only by-passes the need for the oil pressure switch to be closed to feed the pump... When the ign switch is held in the start position. Your system is unlikely to use oil pressure as does mine, however you can perhaps see the logic of the operation..?
I suspect there are many ways for a digital system to determine that the engine is running, using crank position sensor or some such... but ultimately it would again seem logical that if there is a fuel pump relay then it would be the final link in the system which if energised (clicks) when the ign key is turned to START, at that stage the pump should receive an electrical supply, and if the engine then fires up the engine running aspect of the pump circuit should logically take over supplying the link to hold the fuel pump relay contacts closed...
To be sure you are looking at the correct relay, and IF the wiring conforms to the colour codes, there will hopefully be found a white/pink wire leaving the relay on it`s way to the pump...?
Again the relay only energised either when the ign key is turned to START, or the engine RUN circuit is activated.
And as Paul suggests even anew relay can be faulty these days thus even if a relay clicks that does not indicate that it`s internal electrical switch is providing supply to the pump a voltage check is required to prove that it is working, of course if the pump can be heard running then no voltage check required
Last thought... is the fuel gauge operational...? On the off chance that both the fuel gauge and the fuel pump use the same earth wire at the tank connector and it has suffered some sort of corrosion at the connection or wherever it pucks up it`s earth connection to the chassis... worth checking you have a good earth..?
Hope this helps and does not further muddy the water for you.
Being an old Luddite, my thinking could be entirely flawed oldgit
I had the same a couple of years ago, went to pick the brains at the local garage and they suggested trying my spare key, started instantly. Magic 🤷🏼
Simon
2002 4/4
2021 Audi A1 sport
BGW Offline OP
Thanks again to all. Today is another day and I have lots to check and think about! The pump is that of a Ford Focus I have discovered so am trying to locate a Ford wiring diagram which should shed some light on the matter. Will report back once I have tried all of the above. Cheers.
Brendan
2018 Plus 4
It's not a Ford focus pump. It's Honda/Rover...
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
It's a Ford Focus engine but unless they changed something, it's not a Ford Focus pump.
I think it's the pump shown in the link I posted earlier but maybe they changed when they went from the Silvertop Zetec engine to the Blacktop Zetec engine.
If you have exhausted all the fault finding options and you "know" the pump is faulty, you need to start looking at how you will get the tank out.
When you have the tank out, you will be able to correctly identify the pump with Glencoe or some other supplier.
Bob
2009 Black Roadster
BTW, as an alternative to taking the tank out, some people have been known to cut out the piece of wood above the pump and then joint it back in after the pump replacement.
I don't like that method as it's compromising the frame but it has been done. Whether it was successful and gave a secure long term fix to the frame, I'm not sure.
Bob
2009 Black Roadster
I had a similar problem with my car in 2011. The fuse for the pump/ignition kept blowing. My garage found out the factory had screwed wood screws through the wiring loom or cables causing a short circuit, after some time rubbing and vibrations.
Sadly I failed to ask where on the car this happened.
4/4 2 seater 2001 model
BGW Offline OP
Hi Luddite. Thanks for helping. With the ignition on I am getting no voltage on the purple and white. The fuel gauge is working as well as any Morgan fuel gauge does and I am getting a reading of 6.75 volts on the green and black. Next job is a live feed diret to the pump to see if it runs!
Brendan
2018 Plus 4
Page 2 of 4 1 2 3 4
