7 members (RedThree, Davetherave, Grumpy2, Craig Jezz, Aeromax51, Socalm3w, Gambalunga), 256 guests, and 27 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,145
Page 3 of 3 1 2 3
Originally Posted by Leroy
My seat belt springs are fine but find that the folded hood stops it from retracting back if I lean forward then sit back.
It's rubbing against the hood fabric folds, which increases friction, I sometimes have to feed my belt in by hand to help it retract
Yes, that's exactly it. I try to pull as much of the hood away and fold it under the windscreen but it's still foils it somewhat.
2004 Series 1 Roadster
Worth a try, my MX5 has very slow seatbelt retraction. Ordered some and I’ll see how it works.
I am curious what your experiences will be!
Has made an improvement, not perfect but acceptable. It’ll be interesting to see if the improvement lasts.
At my 4/4 the improvement lasts since 6 month.
Of course I fold the "easy up" away from the belt as far as possible and I make sure that no bag or clothes are in contact with the belt.
I think that the spray reduces the resistance of the belt when it rolles up, so that the weak spring is compensated somewhat.
As I mentioned the function -on my car- is now "not perfect but much better so I don´t intend anymore to remove the seat belts.
I had the same problem on my +8 after a hood conversion.
I noticed that the seat belt guide bolted to the top of the rear wheel arch was quite small
compared to the seat belt guide bolted to the back of the seat.
I changed the short guides for a pair of the longer ones. This moves the seat belt further forward and slightly inwards.
I have found, with the hood carefully folded back, there is enough clearance to allow the seat belt free rein.
CAUTION;- I cannot vouch for the safety aspect of this modification since I haven't had time to crash-test my +8 yet!
1994 +8, BMW Calypso Red.
How do you open the boot?
Page 3 of 3 1 2 3
