2 members (mph, Julian BB),
268
89
Topics49,847
Posts837,389
Posts: 64 Likes: 2
Posts: 64 Likes: 2 |
Good morning, is there anybody who has installed the alu rear pannel spare wheel cover from Belmog? If yes, how is the quality and fit? My car hasn't arrived yet, but already thinking about changes  Painted in the same black as the Morgan it will look like the MMC cover for the Roadster. Looks more sporty as with the wheel on the back and can be changed back at any time (if not fix installed) BR Andreas
2003 Plus 8 35th anniversary, obsidian black
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
Andreas I bought one from MMC and polished it. Brands Hatch Morgan supplied it with the badge and brake light. It was around £350 from memory. I also fitted a neoprene seal to stop the paint getting scratched. ![[Linked Image]](https://www.tm-img.com/images/2021/11/24/20211124_110510.jpg)
1 member likes this:
MOGDave |
Posts: 64 Likes: 2
Hi John,
your car is the reason i think about that cover. For the plus 8 the part you have used is maybe not possible i suspect. Or are the screws only decoration? If not bolted, how is the cover fixed? The look is really great. As written by you in the other „cover“ thread, i will use it only for short trips and mount the spare for touring.
It is fitted by the bolts that already existed.
Posts: 64 Likes: 2
so the 8 „dots“ are the bolts? Are there holes in the ... back mmmhhh panel where the spare is normally locates? Or did you drill holes :-0
The holes were there with the bolts already. Originally Brooklands Roadsters came with a spare & a cover. The PO kept I think the cover. ![[Linked Image]](https://www.tm-img.com/images/2021/06/23/20210623_142426.jpg)
Posts: 88 |
Make sure the grommet/seal is thick enough, the rear panel on my car had to be re-sprayed due to damage caused by rubbing - and that was a factory fitted not an after market addition. I was also told not to overwritten the screws for the same reason
Posts: 64 Likes: 2
Thanks, clear now
Posts: 1,155 Likes: 2
Posts: 1,155 Likes: 2 |
Make sure the grommet/seal is thick enough, the rear panel on my car had to be re-sprayed due to damage caused by rubbing - and that was a factory fitted not an after market addition. I was also told not to overwritten the screws for the same reason John did yours even have a seal as standard?
