7 members (+8Rich, John V6, Ian Wegg, Chris Cosher, RobCol, MartO, Barkbark), 249 guests, and 75 robots.
+8Rich 63
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,766
Page 6 of 6 1 2 3 4 5 6
X
xc68anc Offline OP
X
Yes, John, you‘re Right.
It looks like I‘m the only one with fitting the bar on top of the washers. And yes, in the pictures no difference.
Greets René
2018 plus4 (sports green)
The BRB's help support the cross frame, in this case the upper suspension arm so it makes plain engineering sense to have that support as close as possible and in best contact with the frame. The exception is the upper shock absorber bracket which is broad and of substantial thickness to support shock loads and provide wing support, so also needs to be close to the action.
All the pictures I've seen have not had the tyre rubbing blocks fitted. My '74 4/4 does have these and they make the fitting of the Williams supplied BRBs significantly more difficult. The bottom fixing almost fits with the forward mounting bolt of the blocks but I had to move this inboard (re-drilling block and chassis) to avoid the tyre rubbing on the BRB. The rear mounting bolt of the damper retainer also causes a bit of grief. Both fitted now but work needed on both sides.
