Topics49,848
Posts837,406
Posts: 987 Likes: 110
Posts: 987 Likes: 110 |
Peter, is this the reconquista-mog?
2003 Morgan 4/4 2-seater
Posts: 88 |
Yes but Morgan agreed it was not up to the job and changed it.
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
An update. Today after a few weeks and over 500 miles I removed the ali panel to see if the paint was being damaged. Despite fitting a neoprene seal to the edge the panel has left light scratches in the panel. ![[Linked Image]](https://www.tm-img.com/images/2021/12/03/20211203_094046.jpg) ![[Linked Image]](https://www.tm-img.com/images/2021/12/03/20211203_094058.jpg) Luckily these polished out. So time for a rethink as clearly it is either the panel or the spare not both. ![[Linked Image]](https://www.tm-img.com/images/2021/12/03/20211203_101139.jpg)
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
John, I suspect that the seal is compressing enough for the internal rolled edge to catch the paintwork
Even with a thicker seal you may still find that fine particles of muck trapped in the seal abrade the finish anyway
Posts: 37,408 Likes: 977
Posts: 37,408 Likes: 977 |
That's a bugger John, but it's patina really - that cover looks really good as it keys in so well with the bonnets.
Even with a thicker seal you may still find that fine particles of muck trapped in the seal abrade the finish anyway Exactly. I'll keep it & ponder. It will make stunning garage wall art
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
The answer may be to use a thicket adhesive neoprene strip on the rear panel, then remove it when you fit the spare. It's a faf, but body twist means a spacer between the two panels is the best option to avoid marks.
Posts: 1,155 Likes: 2
Posts: 1,155 Likes: 2 |
Adhesive p strip around the edge never had a problem ,don’t over tighten .
Thanks . Something to think about
