12 members (IcePack, John V6, Chris Cosher, Gonze, Alan Patterson, Ian Wegg, DickJ, RedThree, MartinB60, sprinty, GrumpyPa, bmgermany), 303 guests, and 95 robots.
Topics49,847
Posts837,391
DazMog, The Impaler, tlchzj79
Dab of oppo #729195 03/01/22 07:47 PM
In a pinch we used 3/16" drill bits as the pins. 3 are needed. Put the car in gear with the brake off so as to make things go properly. Two bodies are a great help! Been There and Done That!
SeasideNick #729197 03/01/22 08:21 PM
Originally Posted by SeasideNick
Krazy Horse now have one less. My first annual service at just 850miles and KH found that the cam belt was cracked. A little worrying on a 12 month old M3W. I understand that the S&S wedge engine will not have damage if the cam belt breaks i.e, the valves won`t go through the pistons?? Can anyone confirm this ??
I can understand your concern.
It may be worthwhile grabbing a supply of belts while you can.
Stay safe
Dab of oppo #729253 04/01/22 05:46 PM
I bought two of those belts on ebay a couple of weeks ago. I joke that I'm going to wear them as a necklace when I drive around.
(S&S needs to step up....just sayin)
end user
Stevo666 #731734 30/01/22 11:24 PM
So how many "spares" do we need to carry ?
cam Belt , Regulator, Fuel pump ect Ect ?
2019 Audi TT RS
2015 Fiat 500 Abarth 595 Yamaha racing
2013 M3W
1974 MGB GT
Too many Bikes to list
Dab of oppo #731794 31/01/22 03:35 PM
JMD Offline
On long (eg mainland European) trips, we carry cam belt (& fitting kit), regulator, a fuel pump (now hopefully superfluous with the recommended upgrade to a Wabro one), some spare exhaust nuts and the rubber mounts for exhaust/regulator. Now we have done the wonderful Bleazey mod to the drivetrain, we could also take spare inserts for the centa-coupling.
Not all can be done at the roadside but better than being trailered home if one has the (hard to find but potentially vulnerable) bits required to fit at a friendly local garage as an alternative to a trailer trip home.
