7 members (RichardV6, JoeSpeetjens, Zach, Clipper, Morganmike, DCH, teknome),
371
97
Topics49,867
Posts837,612
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
I would contact Librands first.
Posts: 6 |
Good idea. Will speak to them on Monday. Coincidentally, now got the dreaded immobilizer issue so struggling to get the car started at all!
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
The immobiliser issue is worse with a leather covered column shroud, which adds distance between the fob and sensor ring..
Make sure that the sensor ring is as far out as possible. I cut away some of the plastic shroud around the key hole so that the ring is a bit further out. The distance is critical and seems worse in cold weather.
But if you swipe the black part of the key flat against the keyhole, the immobiliser light should go off and you get 30 seconds to put the key in and start.
Posts: 6 |
Can fiddle it a bit with the key and get it to start (usually!), but it's not exactly reliable! Sounds like the best solution is to throw it back at Morgan to sort out properly. Don't want to bodge it.
