1 members (RubyMog95),
297
86
Topics49,880
Posts837,760
Posts: 296 Likes: 3
Posts: 296 Likes: 3 |
Hoping someone might have some insight: my fuel gauge has been displaying 0% for the last few weeks, and I miss it despite its vagueness.
I have previously replaced my fuel gauge sender with the VDO 280mm unit and associated shunt resistor per the thread from a few years ago, so I suspected perhaps a connector had come loose there, but all seems good. I took all the connections apart, and I see about 5V across the wires with the ignition on and nothing connected, and I see about 230 ohms across the sender unit itself, both of which seem reasonable, so I don't seem to have a bad connection.
Any suggestions on where to look next?
2020 M3W
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Could be a fouled sender wire which is a malady of the old sender. They are wires that can get crud on them and cause the circuit to not operate, especially through a computer circuit.
I put in the long sender and a real gauge so I have more confidence in it.
Posts: 296 Likes: 3
Seems to have been a sender issue. I pulled the sender out to change the gasket, and while it was out I measured the resistance at both ends of the range to see if it was working OK. It seemed to be, so I put it back and now it is working fine. Maybe it got stuck? If it fails again I may need to replace it. On a side note, I noticed that the gasket was disintegrating. Not sure now if this is the Morgan original (at less than 2 years old), or the one that came with the replacement 280mm sender, but I got a replacement on Amazon. It is a "VDO 226 053 Fuel Sender Gasket". Old and new below. PLANENUT - you might want to add this to the Alternative Parts List. ![[Linked Image]](https://www.tm-img.com/images/2021/12/12/IMG_3388.md.jpg)
2020 M3W
Posts: 1,738 Likes: 56
Posts: 1,738 Likes: 56 |
On a side note, I noticed that the gasket was disintegrating. ![[Linked Image]](https://www.tm-img.com/images/2021/12/12/IMG_3388.md.jpg) Eeek, that's horrible! As an aside, I can report that since cleaning the very thin wires inside my VDO sender the fuel gauge has been reading accurately and reliably - a thing that hitherto I had considered  .
Andy
Posts: 1,562 |
What did you use to clean them with Andy ? Thanks
What did you use to clean them with Andy ? Thanks Just some very fine emery paper.
Andy
